Question about Motorola Mobility RAZR V3i Cellular Phone
Speaker ribbon how do I change the speaker ribbon in my phone,very new to this so really need step by step instructions with pics if pos
    Brigadier General:
  • 7,752 Answers
  1. Remove the four rubbers on the lcd housing
  2. Use a T6 screwdriver and remove the screws
  3. Using a flatbit small screwdriver gently lift the top of the lcd housing.
  4. once that is removed just take off the camera cable and flexcable.
  5. then take the top lens off caerfully cause it is glued to the speakercable.
  6. once that is remove then diconnect the cable and repeat the same process to replace the old one with the new one.
Posted on Jun 29, 2008
SOURCE:
After installing Windows 10: (1) homepage is too wide, (2) Word ribbon takes up too much space, (3) Chrome ribbon takes up too much space, (4) e mail is distorted (too wide).
It seems that you upgraded from windows xp. If you know how to change the resolution that might cure the problem. Windows 10 doesn't work very well with older video cards.
The interface is different so it is a bit difficult to guide you with instructions to adjust the video resolution
Oct 09, 2015 | Microsoft CompuRegister POS-1000 POS...
I have a WahlDorf sound system no instructions...its WD310HT Home Theater.its a subwoffer an 5 speakers how to connect to TV or DVD?
there is no info for a 310,but,there is for a 305,you need to make some cables for it,you need some rca cables with one end cut off,the rca plugs into the tv audio output,the two wires from each one,go into the push connectors,treat the outside wire as neg(black) and inside wire is always pos(red),,the top 2 push posts on the left are for the left audio from your tv,the 2 posts on the right are for the right tv audio,there are 4 more connectors for another device,like a dvd etc,push connectors operate by pushing in on them and pushing the bare wire into the little hole and releasing,
25715906-ghuqylfbvqx2ddmcce1obb43-5-0.jpg this is the only pic available,the 4 push connectors on the right are,tv right,pos,,tv right neg,then other audio right neg.,,the bottom one is other audio pos,,,,the 4 on the left side are left tv audio pos,,then left tv audio neg,then other audio left nrg,,then left other audio pos,,,
25715906-ghuqylfbvqx2ddmcce1obb43-5-2.jpg this is like what you need,the red is positive and bare is neg
May 27, 2015 | home Audio Players & Recorders
Hi , there is problem with my phone volume. I can
First of all, a temporary solution is for you to use a earpiece. You plug it on your phone and you will be able to hear the callers clearly.
If your phones main speaker is working, then it is the earpiece speaker that is bad. All you have to do is to replace the speaker with a new one. There are two speakers on this phone, one in front, which is the part where you get to listen to your callers from, then another speaker that plays your audio files and receive your calls on speaker mode.
To disassemble the phone, follow the steps below:
  1. Remove your back cover, battery, sim and memory card. Six screws need to be removed,
  2. Run something like a credit card around the join of the battery compartment to release it from the rest of the phone.
  3. Now remove the two screws and you'll be able to lift away the metal plate with the identification sticker on.
  4. A ribbon connector needs to be detached. This attaches like a plug and socket. Just lever it up to unplug. You can now lift the circuit board away from the rest of the phone.
  5. Remove the eight screws you can see. These screws hold the slide part in place.
  6. You can now lift the slide part away from the rest of the phone. Four screws now need to be removed. The two on the left are covered with black stickers which can be easily removed.
  7. Now run your plastic tool all the way round the join of the front cover in order to release it.
  8. Three ribbons need to be disconnected. The two left and right attach like a plug and socket. Just lever each up to unplug. The ribbon in the middle has a different connection. To release it just flick the black latch up and pull the ribbon cable away from its socket. You can now lever the LCD screen out of the front cover.
  9. Then you see the earpiece and where it is connected to, just disconnect it, replace it with a new one, then you reverse the process to reassemble the phone back together.
Take care and good luck.
NB: When making a call, do not put it on speaker yet, then you increase the volume from the side of the phone where you have the volume button. If you do not hear the person calling you, then you replace the earpiece with the steps above.
Dec 20, 2010 | Samsung B3310 Cell Phone
No sound from earspeaker, only on speaker serrting
hi :) here to tell u slide phone much pro effect by the ribbon. even earspeaker cant use,no display,upper keypad no function. all above are effect by the ribbon. u need send for technician replace a new ribbon.
please voted me if my solution useful,thank..
Aug 02, 2010 | Sony Ericsson T303 Mobile Phone (Shadow...
HP Pavillion dv6110us Speakers not working
The sound power comes through a ribbon cable to the power button,along with the power supply switch wiring. This "power ribbon cable"( part # 431437-001) has frayed where it connects to the motherboard.
The new cable will cost you about $5 with free shipping on ebay and takes about 10 minutes to replace.
You can find step by step instruction on the repair by searching "dv6000 power ribbon removal".
Feb 06, 2010 | HP Compaq Pavilion dv6110us Notebook
Download pics off phone to computer...
You might need to get a data cable. I have one that might work. If this is Leiocea from Hilo, give me a call (808) 333-8909. Dave
Nov 09, 2008 | Motorola Mobility RAZR V3
Downloading pics from my motoroal i580 to my pc
you need to first install the MPT-MObile Phone Tools Software then following the step by step instructions.
Jul 17, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Screen broken
you need a new lcd screen.
Replacing the upper screen is by far the hardest to fix, it requires you to feed the LCD ribbon through a hole ¼” wide, you also need to be able to desolder and resolder the speakers on the new LCD ribbon, then feed the new ribbon back through the hole, it’s not that easy.
Jul 17, 2008 | Nintendo DS Console
Omar
its ribbon has damaged, ribbon which connects upper part with lower part.thats why ur screen goes black. take it to technician once ribbon is changed, ur phone will start working like new one. thanks
Feb 28, 2008 | Nokia 6288 Cellular Phone
Mobile Display
sounds like you need a new ribbon cable 1st buy ribbon cable from ebay here are the instructions to change your ribbon cable remove battery/sim card undo 4scews tiny cross heads they are slide phone open ans at the bottom of the phone theres 2 more scews to undo these are under little plastic covers once removed starting from the bottom of the phone insert a thin wedge i use my fingernail just get it inbetween the bottom of the casing and slowly move it round the phone open the casing a little but not 2 faras you have 2 slide the casing off the tophalf of the phone once you detached the casing there will be a plug(loud speaker)just unplug this now you should be a stage where you have removed the back casing,we continue carefully prize out the main baord this will be attached to a ribbon cable so be careful remember to first remove the button and then run your fingernail where the buttons are affixed (there stuck to the casing) ok you have the main board free now turn it over so as you dont damage the cable remove the green sticker which covers the cable then you need a soldering iron to free the cable as its attached to the main board flip up the holding strip and remove the ribbon cable from the main board ok next there are another 6 tiny little screws which attach the sliding chassis remove them and remove the slidehousing ok now you need to undo 4 more screws 2 are in plain view the other 2 are hidden under the top plastic covers once they are removed the slide mech comes away freely and you can see where the the other end of the ribbon is attached again remove green sticker and desolder the pionts lift up plastic retainer and remove the ribbon replace with new ribbon and put back together the same way you undid it sound a bit tricky but its quite simple really. well i hope this helps mrjazon
Aug 20, 2007 | Samsung SGH-E900 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
