Question about ASUS SiS Chipset TUSI-M Motherboard
Computer won't boot up
ASUS TUSI-M w/PC100 PS150 ATX micro power supply. This will not boot up even with trying two different motherboards. Not even so much as a BIOS beep. All the lights come on, the HDD spins etc. The monitor comes up with a self-test saying everything is good with it and to check the computer. Seeing as I can't even get a BIOS beep of any kind, could it be something with the power supply not "channeling" power correctly?
I've tried three different motherboards and am hesitant to believe it's all three motherboards.
I'd appreciate any input and possible things to check into.
Thanks.
    Scholar:
  • 117 Answers
Have you tried a higher rated ATX power supply? Preferably a 350w.
Posted on Jun 10, 2009
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
Msi n9800gt(geoforce)video card problem
Could be your BIOS version doesn't support that grahics card. Try instaling MSI LiveUpdate and flashing your BIOS (LiveUpdate download here: http://global.msi.eu/index.php?func=downloadindex)
If that doesn't help, maybe try another graphics card in the system, see if it'll boot.
Dec 09, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My computer restarts by itself in a never ending loop
I have had this happen to my computer multiple times. Once it was because the system was overheating due to the CPU fan and case fan being dead, and the second time it was due to a short in the power supply. I would check either of those two things.
Nov 11, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
No power how can i resolve it
If none of the front panel lights turn on when you press the power button, then check the power lead is connected properly to the switch mode power supply and to the mains outlet.
Also try a different power cord.
If it still does not power up then the switch mode power supply is probably faulty.
Install a different switch mode power supply in the desktop computer to see if it powers up (make sure the capacity of this power supply is equal or greater than the original power supply).
If you cannot get another switch mode power supply to test in your desktop computer, then take the switch mode power supply to your friendly computer shop and have them test it for you. Replace the switch mode power supply if it is faulty..
Nov 07, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Monitor won't come on
do you hear a single beep when the computer boots? That's a sign of a good system... try your monitor with another computer...the problem might be your monitor.
Aug 16, 2009 | ASUS SiS Chipset TUSI-M Motherboard
ASUS P5VD2-VM SE MOTHERBOARD
If you purchased this motherboard recently then i would double check your power supply - get a better power supply and try that - think you may need one with two 12 volt rails.
If that does not work then I would get it RMA'd as in return it and get a replacement.
Apr 10, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Boot up.
my sugestion is mite try testing it somewhere else mother board mite be bad or maybe power system is to low.lala linda
Jun 02, 2008 | ASUS M2V-MX SE - Motherboard - micro ATX -...
Asus tusi-M
another solution is that you'll just select the cd/dvd as your first priority and then u disabled other boot priorities. ^.^
Sep 13, 2007 | ASUS SiS Chipset TUSI-M Motherboard
ASUS SiS Chipset TUSI-M Motherboard Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
