Question about Canon LaserClass 7000 Plain Paper Fax
Red light blinking and printer error "check printer ##330" appear
Put in new toner cart. and turned machine off for a minute and turned back on, but message reappeared.
    Problem Solver:
  • 11 Answers
## 330 Power Supply (Replace/Repair)
Replacement part number is HH3-5278
Posted on Jul 02, 2010
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
We replaced the toner cartridge and the waste receptical and the little red light "Add Toner:" is still on and the machine won't copy. We have removed the cartridge and did the dance...
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
Jul 07, 2011 | Copystar CS-1810 Copier
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Red light is blinking. Do not know why. How do I
Unfortunately, only way to see the error codes you have to get the printer to give you a green light so you can print out the configuration page. Far as the red light blinking, there could be a number of things it could be.
First, make sure the toner cart is installed correctly
- Check to make sure that there is paper in either the pull out for fold down tray.
- Check to make sure that there isn't a paper jam. Remove the toner cartridge and check to see if there is any paper stuck inside.
If you get the green light after checking those things, press both buttons down for about 2 seconds and release. On the configuration page there will be a set of numbers that indicate what the error codes are. If you can get me that information I can tell what they mean.
Aug 03, 2009 | HP LaserJet 2100 Printer
Yellow toner not being recognized with new toner installed
Probably dirty contacts on side of cart. Also if you take out drum and cart unit together, clean copper contacts with alcohol and cotton bud, also make sure in machine where they contact is clean
May 01, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
AL 1631 printer will not print.
it sounds like you need a new toner cart. does the machine just run & run & wont come to ready. if so you need a new toner cart.
Dec 08, 2008 | Office Equipment & Supplies
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Xerox Phaser 6110 claims new toner cartridge is empty
Could be many things...depends on the exact nature of the problem. Where the machine states "Invalid Toner" either the machine itself or the toner cartridge may be the wrong "region". i.e. has been sold in the wrong country..the initial toners will work but as soon as you put new ones in they will give this message. If the machine is still displaying "out of toner" then either the toner cart itself is faulty (assuming they are original Xerox carts) or the Image Unit could be faulty (the bit they plug into). Failing that, it will be a faulty Main PCB. The Toners on these have a crum chip, so they cannot be just re-filled and some that may seem "compatable" will not work either.....
Mar 05, 2008 | Office Equipment & Supplies
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
833 people viewed this question
old marine
old marine
