Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
I have a DJM 600 mixer and the master volume when i have it on the 5 level, suddenly the sound cuts off by itself, and goes high and low with me not even touching it.The only way to fix at the time is to put the master volume up to 10 level.It does that after 3 hours of playing. I opened it to see if is something wrong inside and everything was fine.
  • 135 Answers
It sound like the master fader is faulty. Look here :-
http://stores.ebay.co.uk/methleykev
Posted on Jul 06, 2010
Volume control of system output is not stable with sudden high volume output bursts. Any ideas?
Sounds like a faulty / worn fader. If it does it on all channels then look at the master fader 1st.
A good source of parts is available here :-
Jul 01, 2010 | Pioneer DJM-600 Silver Professional DJ...
DJM 400 Keep going into over on the channel and the master volume
To keep your levels down keep the TRIM don which is the gray knob. Also keep the hi, mid, and low knobs at the medium level. The control cables are for using the fader start function.
Jun 02, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Dec 04, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600 - fader panel not working
i would recommend checking a fuse somthing with such good quality would less liky need a replace ment unless the power cut really damaged it internily
Oct 06, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Oct 02, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
A DJ Pro Audio Co.
Sep 23, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 800. (dj mixer) when turning the master gain volume it doesnt turn the volume up or down unless you put pressure onto it.
apply some spray (lubricant contact cleaner)from radio shack-----to master gain volume and move it up and down many times.
Sep 09, 2008 | Pioneer DJM-600 Silver Professional DJ...
271 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
