I have a Bose V10. When I press the system button on my remote the menu does not appear. I was programing the setting and mistakenly change the video format. I'm unable to fix the problem due to no image on the screen. Thanks in advance for any assistance you could offer.
  • 56 Answers
REPLY ME, is there any option like "PROGRESSIVE" on the unit or remote. If yes press it once or twice. Hope to solve for your problem. and no such button call the authorised personal from the company for the permanent solutions.
Posted on Apr 23, 2009
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
Tip
Bose LifeStyle 38 Video Mode
Bose LifeStyle 38 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 38 Manual Download
Reset Bose LifeStyle 38 VChip Password
on May 02, 2010 | Bose Lifestyle 38 System
Tip
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
I hope that helps.
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Bose Lifestyle 48 System
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
Bose av28 access menu using control buttons
when this happened to me,,,I found out it meant that the video decoding ASIC was out....I could not get any DVD's to play to the TV, and finally, the "settings" menu would not go on the television screen....this means you need to have the mainboard replaced, and after twice doing this,,,,the Tech on the phone told me that the Video Decoding ASIC is very susceptible to power spikes,,,so I put a big APC filter in front of it....
Jul 06, 2009 | Bose Lifestyle 28 System
What button on Bose remote will erase material on cable box DVR?
Try 'Enter' if you haven't already. A yes/no question on a cable box is usually a toggle, so select yes and press Enter. If that doesn't work, try a different code from the system menu. (Press 'System' and go to 'remote control.')
May 25, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Need to perform factory reset
When I worked for Philips, I solved one of these. First, try unplugging the unit from the wall outlet for one full minute and see if that alone will reset the unit/restore it to defaults. If not, make sure you have a yellow video connector running from the Bose to your TV rather than another type of video cable - change the tv to the appropriate source channel - now see if the menu will appear. If not, you will have to fly blind (don't mess up): Press the System button, then the right arrow by the Enter key twice, then the down arrow by the Enter key five times, then press Enter. Defaults (including NTSC) will now be restored.
-Tha Mp3 Doctor
Dec 30, 2008 | Bose 3·2·1 II System
Cannot access the System menu on home theatre
for sure call tech support from bose they are very helpfull
Dec 28, 2008 | Bose Lifestyle 18 System
Bose Life styles NTSC to PAL
First, using the remote Turn the unit off.
Then, using the remote Turn the unit on.
Next, Press the [System] button
Next, Press the [Right] Arrow (once)
Next, Press the [Down] Arrow (4 times)
Next, Press the [Up] Arrow (once)
Next, Press [Enter]
Last, Press the [System] button
Done
Apr 12, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Incompatible Video Signal
i forget exactly how to do this, and i know how to do it, but your menu should still display on your tv when you press the menu button. but,,,,
worse i did it in a hotel and had to get engineering to fix it for me....
you need to reset the system, the instructions are in the manual,
but to get your picture dislaying on your tv, get an adaptor for the end of your scart cable and plug the yellow video component into the AV socket on your TV. this should work until you wade through the manual. even though the picture wont be good.
Mar 01, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
233 people viewed this question
 Grubhead
Grubhead
