Question about Cadet Manufacturing CADET Softheat Portable Hydronic Baseboard Heater 1500 Watts 120 Volts 72 (EPA1500/3W) 13169
Oil-filled SoftHeat baseboard heater makes loud gurgling noises
We have several 5 - 6 yr. old 'Cadet 'SoftHeat' baseboard heaters - one now makes a loud gurgling noise while in operation. It ised to be completely silent. There is no sign of oil leakage. The product is now possibly out of warranty.
  • hamishtear Apr 22, 2009
    Nope - this is a self-contained, sealed, plug-in heater with glycol fluid. The Model number I quoted is right on it.
  • 5 Answers
I work at Cadet and what has happened is the heat transfer fluid which is a water glycol mix, the heater has a small pin hole leak that has allowed the water to evaporate out. There is no fix for this so the heater will need to be replaced. If your heater is still under warranty they will replace it at no charge. Call 360-397-2505 and ask for Tech Support. Make sure you have your model number handy.
Posted on Jan 19, 2015
I have the same (I think) electric baseboard heater (no, it's not a boiler system). Actually, we have three. Recently, one started making the loud noises, then it stopped working two days ago.
I'm wondering if the original poster ever found more information, or if anyone else has an idea. There is still power to the heater -- the little light on the knob is on. There's just no heat.
Thanks!
Posted on Dec 11, 2009
    Problem Solver:
  • 19 Answers
Is this for a boiler system
Posted on Apr 22, 2009
SOURCE:
Installing a cadet softheat hydrondic baseboard heater on 12-2 wire on 20 double switched breaker. Is this possible? I was told I could change the white wire to black giving me one black to each prong of...
Yes it is acceptable and common practice. You do not need a neutral on a 220 Volt circuit. Just wrap it with black electrical tape so anyone who gets into the wiring later will know that both are hot. This is accepted by the National Electrical Code.
Feb 13, 2011 | Cadet Manufacturing EBHA1000W The EBHA...
I am interested in purchasing baseboard heaters, particularly I have been looking at the Farenheat PHH15002 baseboard heaters. I am purchasing an 1100 square foot 2 story condo with 2 bedrooms and a...
#1 you have to calculate the heatloss of your rooms,that will tell you ur wattage require. Oil filled or not,it's just as dry. As far as ur load to panel breakers, a rule of thumb is approx 3600 watts for 20 amps,using a number 12 wire. But ur wall heaterS should suffice
Apr 21, 2017 | Fahrenheat PHH15002 Oil Filled Baseboard...
Good day, I just moved into my new home on August
It sounds to me that the motors on the units in question, may need a few drops of oil on the bearings. I have seen motors in these heaters and most do have a place to oil them, they wouldn't have sealed bearings as the newer motors.Check the blower wheels also for dirt build up on the blades, as this will cause them to be out of balance and cause some noise also.
Sincerely, shastalaker7
Oct 28, 2009 | Goodman GMS90703BXA Heater
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Heater is excessivly noisy, can be heard over tv
first, my research into the Cadet model #09954 is a 240v unit. if it is wired to only 120v that may be your problem. I am not even sure it work work on 120v.
Feb 11, 2009 | Cadet Manufacturing 09954 Baseboard Heater
BASEBOARD HEATER NOISE
HOW ABOUT THE MARTIN HEATERS I LIKE THEM BUT DONT USE THEM THAT HIGH
Dec 04, 2008 | Fahrenheat Electric Convector Baseboard...
2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Nov 17, 2007 | Heating & Cooling
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Heating & Cooling Logo
2,188 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
