Question about McCulloch FHH18A Electric Pressure Washer
My power washer does not let the soap come out when you turn the soap control on
You have to use the SOAP nozzle (Black Tip)  It is a low pressure nozzle.  The venturi effect prevents the psiphon under high pressure
Posted on Apr 23, 2009
How do I solve my problem with my pressure washer not sending soap?
Pressure washers usually will not draw soap on high pressure setting. Switch wand or set wand to lower setting. Pin hole leak in soap line can also cause problem.
Jan 22, 2015 | Craftsman 2700 PSI Briggs Stratton...
How do I get the soap to work on a power washer
you have to use a large tip in order to get soap and also check to see if the soap hose inlet is open
Sep 17, 2014 | Devilbliss DeVILBISS Devap DVH2600...
How do i install my soap dispenser into the 1600 all-power electric power washer
There should be a 1/4" hose nipple on the pump which will connect to the soap dispenser with a 1/4" line.
Sep 28, 2013 | All-Power America Garden
Washibng machine switches on but nothing happens.
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 2: Make sure the control knob is properly set to the ON position and the door is tightly closed. Check the latch to make sure it's free of lint and soap buildup.
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
Apr 29, 2011 | Bosch WFL 2062 Front Load Washer
Hi, My washer does not do the final spin.....Everything else seems to work except the final fast spin. Is there anything i can do?
Stop using so much soap? These newer washer must use a slight amount of HE soap. Any other thing will cause motor over amping, burn up sensors, and cause the control to work overtime trying to remedy the problem. F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
More Here
Dec 29, 2010 | Whirlpool Washing Machines
How to use soap dispenser on Karcher K2.87 power washer
Also, be sure the cap is turned to the direction that lets the soap in. It has a gradation on it and if it is turned all the way to the smallest (cap fully closed) very little soap will be injected into the stream.
Apr 18, 2010 | Karcher Garden
Washer stopped in rinse cycle.
Sounds like a control or door lock problem. Try resetting you ccu ( computer control) by unplugging the unit for 30 minutes first. If this does not work then you probably have a bad door latch or bad ccu. You should have a technician do this repair. The wrong soap will not cause this problem, although it can eventually cause other problems. Good Luck, Appliance Specialists
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
No soap comming out of my power washer
I had the same problem on the same unit. All you need to do is pull out the front tip of the gun nozzle to engage the soap dispenser. It's as simple as that, but because there is only a tiny footprint mention of this in the instructions, it turns out to be a long drawn out problem for many of us. Hope this helps.
RP
Apr 22, 2009 | McCulloch FHH18A Electric Pressure Washer
On my karcher pressure washer, how do i get the soap to come out of the spray nozzle?
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Apr 13, 2009 | Karcher K2.26 Electric Power Washer
McCulloch FHH18A Electric Pressure Washer Logo
604 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
