Question about Olympus Camedia C-350 Digital Camera
Transfer photographs from camera to computer - how do I do this
I have a USB cable connected to my computer and camera but it does not connect.
  • multilinkmkt Apr 22, 2009
    Thank you. We found out that we just insert our memory card into the side of the computer and we were able to copy and send the photots we wanted to. Didn't need USB cable.
    Thanks for your help though.
    President:
  • 919 Answers
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Posted on Apr 22, 2009
How to import picture from Samsung camera PL120?
Transferring files by connecting the camera
as a removable disk
Connect the camera to your computer as a removable disk.
1 In Shooting or Playback mode, press [m].
2 Select Settings - PC Software - Off.
3 Turn off the camera.
4 Connect the camera to your computer with the USB
cable.
Transferring files with Intelli-studio
Intelli-studio will start automatically when you connect the camera
to your computer with the USB cable.
The battery will charge while the camera is connected to a computer with the
USB cable.
2 Select Settings - PC Software - On.
cable.
5 Turn on the camera.
• The computer recognizes the camera automatically and
Intelli-studio launches automatically.
6 Select a destination folder on your computer, and then
select Yes.
• New files stored on the camera will automatically transfer to
the selected folder.
• If your camera has no new files, the pop-up window for saving
new files will not appear.
Rate my answer if this helped you.
Sep 13, 2011 | Cameras
I have been using my G11 with no problems for a year. Just tried to download pix and keep getting "Communication error". Checked the cord, it's fine, turned camera off and on several times,...
hi kbailey. Turn on the camera and go to the menu. find the reset function. Reset the camera. This means you are returning it to all of the settings it was at when it was brand new out of the box. Joe
Thanks for choosing Fixya!
Nov 26, 2010 | Canon PowerShot G11 Digital Camera
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
When i connect vivitar vivicam 3815 with usb to computer it does nothing!
Some cameras need to be configured to connect to a computer before connecting it to a computer. Please see your manual. If it doesn't need to be configured, try connecting it to another usb port on your computer. You have to make sure that the usb cable your using to connect the camera to the computer is not defective. Try using another cable. Also, try connecting another device to the computer using usb connection to make sure that the usb port is not damaged. If again, nothing happens, then you have to consider that the usb port on your computer is damaged and you need to contact your computer's manufacturer for it.
Nov 23, 2009 | Cameras
Connection of camera to computer
This can cause by a bad usb cable that you're using to connect the camera to the computer, so better try to use another USB cable and also connect the camera to another USB port on your computer so we can check if the USB port is bad or not...
May 15, 2009 | Canon PowerShot SD1000 Digital Camera
Computer will not detect camera when connected via usb
First thing to do here is to try connecting the camera on a different USB port on the computer if its a tower connect the camera on the back USB port of it, if still not detected try connecting the camera on another computer and check if it will be detected , If still not detected the problem here can be with the USB cable that you're using so better try a different USB cable...
Hope that helps............
Sep 19, 2008 | Canon Cameras
USB Connection. When connected to computer camera shuts off or displays USB error.
you have a faulty usb cable. try to buy another usb cable which supports usb2.0 for faster data transfer.
Mar 23, 2008 | Cameras
USB cable
Yes, the CB-USB4 cable that comes packaged with the camera is required to connect the camera to the computer. The stock number for a replacement cable is 200 776
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
General USB Troubleshooting
While USB connections are significantly faster and easier to set up than older serial or SCSI connections they are not foolproof. Here are some tips: Be sure to connect the cable properly One side of the cable is "keyed" so it will only fit properly one way. Do not force it in if it does not smoothly connect. Notice how the USB plug is "keyed" and will only fit properly in one direction. The USB connector on the back of the computer. Connect directly to a USB port on the computer. While USB hubs allow many devices to connect to a computer they are not always reliable for high-speed connections like digital cameras. Connect to a port on the back of the computer. Many computers have extra USB ports on the front or on the keyboard. These are generally built-in hubs which may cause problems as described above. Connect to an AC adapter or use a freshly charged battery To prevent problems during transfer be sure that the camera has enough power to complete image transfers. Remove other devices To troubleshoot problems, remove any other USB devices and connect just the Nikon product for testing.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
75 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
