Panasonic projector lamp
Hi how can i teli if the lamp is no good i have just got one of ebay i can not test it as i have still got 1100 hours on the one in the projector i have a panasonic pt-lc55e can you help thanks
  • 2,237 Answers
The only way to tell if a lamp is good is by checking the inside of it for bulges, black spots, and fogging. or put it in the projector. best bet: buy a new one.
Posted on Dec 22, 2009
How to replace the lamp for Panasonic projector
If you bought a lamp from eBay then its most likely not a real brand bulb. The PT-AE1000 uses an ET-LAE1000 lamp that should have an Osram, Philips or Matsushita brand bulb. If you do not see PVIP, M or UHP on the bulb then its most likely your problem. Cheap lamps are not worth the money. They fail early and end up costing you more money in the long run. Panasonic Projector Lamp
These folks sell lamps that always work. I would return the eBay lamp and buy one that will work. Their support and customer service are one of the best in the industry.
Aug 11, 2015 | Panasonic PT-AE1000E Projector Lamp...
I need to zero the lamp hours on a panasonic PT-AE900E projector
Hi. Press menu and you'll see the menu on screen. Go to options, highlight the runtime hours figure, and press and hold the "enter" button. The hours figure will change to "Power Off" which is what you do next, good luck!
Oct 19, 2011 | Panasonic Lamp For Panasonic PTAE900E...
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
    the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
    Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
    Panasonic PT-60LCX64. What would happen if you
    you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
    Nov 09, 2009 | Mitsubishi VLT-XL2LP Projector Lamp for...
    I have an Optoma EP716 projector. It has run for
    either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
    Oct 22, 2009 | Optoma EP716 Multimedia Projector
    Last night, a message started appearing saying the lamp needed to be replaced on our Panasonic LCD TV. What is this and is it something we have to do? I think it's the Panasonic PT-AX200 LCD Projector, but...
    the lamp is good for about 2000 hours. after this, the lamp may still work, but not as well or for very much longer. after you replace the lamp, you have to reset the lamp timer (in the menu settings).
    Aug 10, 2009 | Panasonic PT-AX200 LCD Projector
    Panasonic projector PT-L78 lamp reset
    Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
    Feb 25, 2009 | Panasonic PT-L785U Multimedia Projector
    Panasonic PT-L557U Bulb Life
    lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
    Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
    1,198 people viewed this question
    k24674
    Marvin
    Marvin
