Question about Sony Multiscan E530 (White) 21" CRT Monitor
Sony E530 focus (?) problem
The picture of my Sony E530 monitor after a while turn to blurred (bad focus) in an instant. No transition. It becomes blurred suddenly. I can put an end to this state if I turn off the monitor with the main switch, wait the LED goes out, than turn on again. The frequency of this fault is varying from 10 minutes to 5 hour. There's no other problem with the monitor. (Manufactured: 2002-04; Ser. no.: 6015233; Model: CPD-E530) Thank you for the help in advance.
I think it can solve with this way:
Press Menu on the front panel of the monitor. Then press OK button and go down and go to COLOR : PRESET. Press OK and go down. Press IMAGE RESTORATION.
My E530 monitor is more clearly, now.
L.E.
Posted on Nov 24, 2008
SOURCE:
When TV is inititally turned on the picture is perfect. After a few minutes or more, the picture becomes blurred. On a scale of 1-10 (10 best) the view is about a 6-7. What can I expect? What are the...
That sounds like the focus is going out of specification due to a dry solder joint or bad connection.
Checking the EHT distribution box for a bad connection could be fruitfull.
Use utmost care as lethal voltages are at this point!
If the picture recovers slowly it could be a tube base problem.
I don't think it will be much other than the Focus voltage is going up and down.
Jan 02, 2011 | Toshiba Televison & Video
How do I prevent constant blurred pictures when taking shots of kids in my family. It also takes at least 3 seconds from when I press shutter button to when camera takes picture..often too late to get...
You need to practice the correct shutter button technique. You need to press the shutter button half-way and wait for the focus to lock (it will beep) and then, when the moment is right, press the rest of the way for an instant picture with no "lag time".
Nov 12, 2010 | Sony Cyber-Shot DSC-P100 Digital Camera
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Picture Image Becomes Blury When Recording
i had the same problem i just gave the camera a good smack and it was all good. lol
Apr 19, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Feb 04, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Blurred picture
the problem of you tv is the CRT socket ,replace the socket.
Jan 07, 2009 | Toshiba 32HF73 32" TV
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Picture focus problems
make sure there is no flower icon on bottom left corner of screen-very common on sony to hit macro button to turn on by accident and you will get blur-only for extreme closeup-hit flower button to turn off if on and let me know if that was the problem
May 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
Dec 25, 2007 | LG Studioworks 775N 17" CRT Monitor
Open Questions:
See all Sony Multiscan E530 (White) 21" CRT Monitor Questions
Sony Multiscan E530 (White) 21" CRT Monitor Logo
227 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
