Question about Honeywell Programmable Thermostat Heater
Honeywell Electric Baseboard Heater thermostat
I have a basic Honeywell EBH Thermostat on my wall. I woke this morning and no heat in the living room at all. Turned it up so it "clicked" but still nothing. Any ideas???? Maybe the thermostat is gone? Needs to be reset some how....????
    President:
  • 1,902 Answers
You need to take the wires off the thermostat. And touch the red and white wire together. If the heater works then you need a new thermostat, if it does not work then you need a new ignitor. It all depends on the t-stat. Dont worry about the wires there are not enough volts to hurt you. It is milli volts so just touch them together and the unit should fire up
Posted on Apr 22, 2009
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Want to replace analog Honeywell thermostat with digital
Your system uses 24 volts and that thermostat should work. You should only have a two wire system and that should work using the RH and W connection on the thermostat. My personal opinion about that thermostat...I don't like it. It will timeout for 15 minutes after furnace does not fire up. I deal with this thermostat all the time because that is what they install in the new homes. I always have to pull it off the wall, remove the batteries and wait for it to completely drain power becuase it does not have a reset switch. Very irritating...Might be too complicated for your application.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
Thermostat burning walls
your thermostat may not be made for electric heat, if not then your wiring is overloading the thermostat causing the wires to heat up.
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
180 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
