Practice guitar amp will not turn on
Practice amp will not turn on
    Novelist:
  • 153 Answers
Dead power outlet (does a lamp light up in that outlet?), cord not fully plugged in at one end or the other (remove and re-insert), blown fuse (replace with same type and rating), dead unit (requiring repair).
Posted on Apr 22, 2009
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
Is there any way to make the hb15tsk louder acoustically,I love the guitar.
In a word, NO. Changing type of strings might make it a bit louder, however the sound quality would drastically change if it does. Best to leave alone... Get a small amp, portable battery if needed... OR there are headphone amps that are designed to be used for practice.
Sep 02, 2011 | Washburn HB Series HB15CTSK Electric...
Having just purchased a new 3amp MicroCrush on ebay I am disappointed that it is impossible to get a 'clean' sound. I have tried every combination of switch settings on the amp and my Gretsch 5122...
You are using a Gretsch with this? This is a tiny amp useful for ONLY low levels as a practice amp. If you turn up the gain the unit will distort as the tiny speaker just can't handle high levels. An appropriate level would be if *********** could tolerate sitting alongside it. For the hum situation... does it hum with NOTHING plugged in? If so, probably the wrong adapter is being used. If it doesn't, then your guitar is probably picking up magnetic interference... major source of that type interference is "wall warts" power adapters. The only solution is to keep distance from the source to your guitar. Poor quality guitar cables can let in hum as well.
Jul 14, 2011 | Orange Amps Orange Micro Crush Mini...
I get a humming sound when I plug my Gibson SG straight nto the amp. The noise fades and strengthens depending the positioning of the guitar in relation to the amp.
Your Gibson is sensitive to magnetic fields You need to keep the guitar about 10 feet away from the amp as the power transformer is radiating magnetic fields that is causing the hum. Solutions: there aree several... most are NOT practical... such as encasing the transformer of the amp in Mu-Metal shielding. Changing the transformer to a toroid type (they should deliver them that way) encase the amp in a thick steel cabinet... all this is ridiculous... putting distance between teh amp and the guitar is probably the only practical solution. The level given any particular orientation should fall off with the square of the distance. Note that OTHER stage equipment also will have transformers that radiate. Much of the new amps do NOT have power transformers that run at low frequency so they don't have this problem. Marshal is old school and they use the older power supply designs that radiate the magnetics.
Apr 16, 2011 | Marshall Amplification Marshall MG15FXMS...
When i play my bass through my amp it is really loud but when i go round my tutors for lessosns he has to turn his amp way up to get any sound at all.
His amp probably has lower gain. They vary quite a bit. Also the size of the speaker will affect it a bunch. If his is a tiny practice amp your bass will not generate much noise.
Mar 18, 2011 | Washburn Taurus T14 4-String Electric Bass...
Guitar cable was under the amp, i picked up the guitar and it pulled the jack. it picks up static but not sound
The cable has a broken wire. If it's the type cable which allows unscrewing the jack, take it apart and look for a loose / broken connection. Repair would be to solder it back. If the jacks on the cord are the molded type, the most practical solution is to replace it.
Charlie
Feb 21, 2011 | Epiphone Les Paul 100 Electric Guitar
Not getting enough distortion(esp ltd ax-260)
It's not your pickups. It would be nearly impossible to loosen a wire inside of your guitar by having even heavier than your amp head drop on it. It is most likely your volume pot. The post, if hit hard enough, can virtually distroy your pots. Another possibility could be your jack, al though considering where it's located on your guitar, it would be very hard to damage it by having something drop onto it.
There is little else that could be the problem. Hopefully you didn't damage your guitar too badly. If the guitar was in front of me, it would be a relatively easy diagnosis.
Fortunately, volume and tone pots are inexpensive, and if you're handy with a soldering iron (or you have a friend that is) it is an easy install with four to six solder points, depending on your configuration. I don't want to assume it's a stock setup, but when you take off the rear electronics cover, you will immediately see what configuration you have.
If you have possibly damaged the pickup bobbins (assuming you have the stock humbuckers in your guitar), you would be able to see the damage, It would either look damaged,or work correctly. As you know bobbuns are simply wound wire, and that's not easy to damage. Plus your strings provide a minimal amount of protection, unless your amp head slammed it very hard. Start by replacing the volume pot. Cheapest parts first. There is no way to test the pot with anything like a potentiometer, because there is virtually no voltage that passes through the pot. Additionally, unless you have active pickups, your pickups cannot be either. If you do have to replace your electronics, you can find a large variety and even upgrade your parts by searching eBay. The good thing is that you havce a guitar, and guitar parts are abundant, relatively cheap, and most people change out electronics just to achieve a different sound.
If you are so inclined, most good guitar shops will diagnose your problem for cheap and apply the cost of the diagnosis to the cost of the repair. Good luck, and I hope I have given you some information to work with.
Thank you for using FixYa
Jun 19, 2009 | ESP Ltd EX-50 Electric Guitar
My Behringer gx212 ultratwin amplifier started to lose volume last night at band practice and then I smelled buring wiring. I think I lost or am in the process of losing the amp transformer. I think the...
Hi I just recently purchased a Behringer GMX 212 and had similar volume dropout on the clean channel only Channel 2 works better and has more punch in clean mode.I went to the shop where I purchased it with a 7 day warranty from some indian dude here in Nadi Fiji, and there was another GMX 212on the floor so I decided to try it out. This was a new amp. I plugged into the clean channel and turned it up full volume on guitar and amp adn heard the volume drop of in the amp in almost a curve and then the whole amp just cut out. We unplugged and waited, turned the amp off, and then on and stil no sound. We then tried the guitar and cord in another amp. The other amp was fine. Can you solve this problem.......my gut feeling is this happens a lot to Behringer amps.
May 08, 2009 | Audio Players & Recorders
202 people viewed this question
 Grubhead
Grubhead
