Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Fridge doesn't stop running
Fridge freeze very well, it just doesn't stop , even if you put the setting at one, it runs for a very very long time
is it the thermostat ?
I noticed that the pipe outside that goes into the feezer compartment gets all frosted after 10 minutes or so
I can make it stop between 0 and 1 and will restart but still run for a long time, it is a belanger frost free around 25 years old
  • 170 Answers
Number one when you can always provide model number and make...it helps enormously in troubleshooting otherwise you get these long detailed threads...from an anal tech like myself.
{Which you did provide...this is a plug-in thread I am putting in for you..Belanger...check your condenser...to see how clean it is..it sounds as if...the motor could be going out or not turning as fast an rpm as needed to remove the heat...(or it is dirty)...good luck...and always there is the compressor.}
Cold is a relative term....how cold...use a thermometer...and determine if the freezer...is at least..10-20 degrees or colder if not it is not cold enough...and here are some generic answers for that problem....I will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the refrigerator side compartment..there is usually a baffle...that controls...the amount of air-flow into the frig side...it can be adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Apr 22, 2009
  • Edouard Blinn Sep 12, 2012
    Hi, I need someone in my area to help fix high pitched whining noise of a whirring noise. Montreal, Quebec H2T 2E3
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Everything freezes
Make sure it is level.
Nov 25, 2013 | Hotpoint Refrigerators
Hi there We have a kelvinater fridge, it is quite old but not that old that you don't get parts for it anymore. But anyway the thing is broken, first the gas but thats fixed, we even got a new...
if the compressor runs but the fridge never gets cold, toss it, if the compressoris not running replace the start mechanizm, also check to make sure the thermostate is putting power to the compressor when you turn it colder, if not... then replace the therm
Feb 05, 2013 | Refrigerators
Fridge keeps freezing food
I have a 6 year old Kenmore Elite top freezer.. I have been dissapointed from day one with this fridge.. the fridge has air vents all over the inside of the fridge. We find that if one of these vents have anything in front of it that something somewhere else in the fridge will freeze. Its very frustrating.. I find that I loose allot of fridge space because I am always juggling space to make sure that these vents are always open... very bad design.. sounded like a good idea at the time.. but never again..
May 08, 2012 | KitchenAid Refrigerators
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
1,538 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
