Question about Hotpoint WMA44 Front Load Washer
Bosch logix ixx 1400 express
I have fowl water building up in the bottom of the machine and i release it out the emergency drain pipe at the front of the machine. the smelloff the water is extremly offensive can you help with this problem
Put in some neater clothes
Posted on Oct 09, 2007
Changed the element in my bosch washing machine and still trips the electric ,can i wash on a cold wash without tripping the electric.
In the washing machine your hot water supply comes from your water heater. The element that is tripping is part of your electrical so no you cannot expect a different result. You will have to fix the problem first before you wash.
Feb 19, 2015 | Bosch Washing Machines
My bosch classixx 1400 express washing machine drain pump sometimes does'ent work
bosch classixx 1400 express washing machine drain pump This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 13, 2013 | Bosch Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
No water drains out of drain plug on Lg washing machine
hi there, this could be one of two problems 1, you have a block in the waste pipe or pump? or 2, your drain pump has packed in and may need replacing?
however if memory serves me right there is an emergency drain tube on LG machines, it should be located behind the bottom pannel on the front of the machine and from there you should be able to release the water from the machine. hope this helps!
Jul 04, 2012 | LG WM Washing Machines
My bosch classixx 1400 express washing machine has become very noisy when draining water, it never used to be. Any ideas?
If it is only noisy when draining the water, then could be something stuck in pump.
There should be a filter located at the bottom front right of washer behind a cover.
Unscrew anti-clockwise to remove and clean, and look inside the pump opening as well to see if anything is stuck there.
Apr 13, 2010 | Bosch Classixx WFL 2462 Front Load Washer
Bosch logixx 1400 express washing machine spin is not working . ALSO THE WATER IS NOT BEING DRAINED OUT IN THE NORMAL CYCLE
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Apr 10, 2010 | Bosch Exxcel WFX 145S Front Load Washer
My bosch classixx 1400 express is not draining off and has a lot of grey stuff on the clothes is this dirt
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 21, 2009 | Bosch Washing Machines
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
Hotpoint WMA44 Front Load Washer Logo
144 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
