We have thin white horizontal lines across the top of our 27'' Toshiba TV. They extend down about 3-4''. You can see through them but it is very distracting. Is there a solution for this? They run across the entire width of the TV screen.
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect?
2.Or is thin Horizontal lines evenly spaced around an centimetre apart?
If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning.
If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
