Question about Apple iPod nano
Getting started I don't understand how to use this, I can't understand the manuel how to start using, charging now.
  • 21 Answers
Hold the "play/pause" button to turn the iPod on.
To navigate the iPod, you can run your thumb over the wheel in either direction.
simply press the middle button to select it. to go back, press menu.
Posted on Oct 17, 2007
SOURCE:
Take the top cover & owners manuel to get at spark plug
I really don't understand your question.
Here's a link that will get you into a lot of excellent training info for chain saws.
https://www.google.ca/#q=chainsaw+basics
RULE # 1 - Chainsaws are dangerous so KNOW WHAT YOU ARE DOING BEFORE you start the engine.
Dec 29, 2015 | Garden
Hp 6715s laptop battery charging bat battery backup not starting problem solyution
If I understand you correctly, you are saying the computer will run with the AC adapter plugged in, but will not start on battery power even though the battery appears to be charged. Most likely the battery is defective. If it won't run on battery power with a known good battery, then there is a problem in the power control circuit on the main logic board inside the computer.
May 25, 2012 | Computers & Internet
Why won't my car start without getting a jump? Once I get it jumped it runs really good but when I turn it off and try to start it again, it won't start. I have a new battery and a new alternator...
Buy yourself a volt meter and check the batter voltage before and after it starts. You should read 12 volts before starting and around 14 volts once it starts and the alternator is charging the battery. Also check for loose connections between the alternator and battery. Check that the ground wire from the battery is secured to the vehicles frame. Good luck!
Oct 18, 2011 | 1987 Audi 5000 CS
I am trying to use my start-it pro system for the first time to jump start my vehicle. Can someone please tell me where does the power connect to the actual 12 volt dc supply. I have 2 things 1. The yellow...
When a question is presented to any forum, model number(s) are essential. Please provide any that you have and if you would. Just to make sure I'm fully understanding what you're asking, would you please rephrase your question?
A lot of models don't come with an AC/DC wall charger and it must be purchased separately but I'm fairly certain there is an alternate method to charge your unit. I'll be able to specifically determine how, once I have the model number.
FYI: The VEC070 1.5 Amp Automatic Charger is a commonly used charger for this type of jump-start system. Don't buy anything until we're certain.
Sep 08, 2011 | JUMP START SYSTEM
I don't understand how can i partioned the hard disk
u can only partition the hdd by using server utility CD. this server starts with this disk only and after
partioning its asks for windows server disk then u have to provide the server cd and installation will done. but before start server using this disk make sure ur sata planner in the BIOS must be disabled other wise windows will not be installed.
i hope this will solve ur problem. if not feel free to call me at 09467754954 wihout any charges
technical support over voice is totally free.
Aug 17, 2011 | IBM x3400 Server
Car starts in the moring everything showing good charging but about 10 to 15 min. car warmed up gage dropes to 8 not charging car dead check battery good what next.
Try charging your battery with a battery charger, then run your engine. If the alternator is good, it will show a slight charge ,but not all the way over. I really don't understand when you say not charging car dead.
Jul 19, 2011 | 1986 Chrysler LeBaron
BATTERY FLAT AND ON CHARGING RADIO IS NOW OFF AND
your sentence makes so sense - please reword it
Dec 26, 2009 | 2004 Ford Focus
Just got it
hold down "Play/Pause" with hold switch off.
Sep 23, 2007 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
