Question about Motorola Mobility HS850 Consumer Headset
Pairing i have the motorola headst hs850 and when i try to bond it to my phone whicjh is a palm treo 755p the light wont go off for it to bond?
  • nes25 Sep 23, 2007
    i did nand it still doesnt pair
    Sergeant:
  • 274 Answers
Make sure both are in pairing mode. Then try it again.
Posted on Sep 23, 2007
  • Jerry Hess Sep 23, 2007
    I did some checking for you and this is what I found.
    First, if you are within the 90 day period since you bought your Palm 755 you can get "free" support directly from Palm.
    Second, you need to go to this website:
    http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.E...
    The instructions on how to make the pairing are detailed and long. If you carefully follow them you should be able to fix this problem. If it does not fix the problem, go the "troubleshooting" link at the same site and again you will have detail instructions on how to fix it. I simply can not copy all the instructions for you because there are graphics involved also.
    Wish I had a simple fix but in this case I do not. Let me know how it goes. Good luck.
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Palm treo sees the Motorola H505 device but will not pair or even ask for passcode.
In my earlier attemts, the H505 headset was probably never in "pair" mode although I was seeing a steady blue light or if it was, it was trasmitting previous Motorola Razor profile to which it was paired to. Once I found on Motorola website that other similar Motorola headsets (without power switch) can be reset by holding the two volume buttons and call button simultaneously for 10 seconds, I did reset the headset and there after my pairing attempt was successful..i.e. it stopped and asked me the passcode before throwing security error. Thanks for your support thought!
Oct 02, 2009 | Palm Treo 755p Smartphone
Unlock Palm Treo 755p
palm treo 755p doesnt have a sim card tray!
sorry
Mar 03, 2009 | Palm Treo 755p Smartphone
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
i unlocked my Palm HTC using codes from http://www.mobileunlocksolutions.com/ , try if your phone is listed for unlocking
Feb 07, 2009 | Palm Treo 750v Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Loading Palm Treo 755p Software onto laptop with Windows Vista
Make sure it is a 32bit operating system on you laptop...if your operating system on your laptop is a 64bit it will not work. Check the Palm support website to see if they have a current download
Jan 06, 2009 | Palm Treo 755p Smartphone
Palm treo 755p not answering calls
Have you tried to restart your phone?
Jan 03, 2009 | Palm Treo 755p Smartphone
Tranferring ringtones from SDcard to palm treo 755p
You can use a FREE program for the palm OS called minitones, you can yahoo or google it, which will allow you to convert mp3s you have on your SD card or on the phone to a ringtone that you can assign to a contact. minitones.prc
Mar 23, 2008 | Palm Treo 755p Smartphone
Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Nov 11, 2007 | Palm Treo 700p Smartphone
Motorola Mobility HS850 Consumer Headset Logo
32 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
