Question about LG 50PC3D 50 in. Plasma Television
Have sound and still picture
Picture starts to play when first turned on then goe's to a still position with volume plus remote does not respond to any commands
  • ericpark72 Nov 14, 2008
    i'm from canada..
    i moved texas a few month ago...than i pluged tv..there were no image come up..still could hear sound which is zig .but no image....
    moving company did nothing wrong....they said..
    i called lg waranty department ..they said we need fix from there..."canada"
    what do i need to there anything i can try???
    Problem Solver:
  • 5 Answers
Are u using cablecard. unit has major issues when using card/\
Posted on Feb 19, 2010
Volume/sound will not increase up on my Samsung HL61A650
If the volume indicator appears and respond as you increase the volume but the sound does not respond, there might be a problem on the audio section.Ask for a repairman to check it. If the indicator does not respond, try using manual control instead of using remote control.Also some units have features to turn speaker off or on. Go to menu scan for audio check if it is turned off or on.
Oct 21, 2010 | Samsung HL61A650 TV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
No sound from my Pure-Fi Express plus into my 4th gen Nan Ipod
Hi, while your pure express plus you just purchased is not playing out any sound is because, the speaker that enable you to play the sound when you play music through the ipod is faulty and it needs to be replaced with another one for it to function properly again.
After changing the speaker that is faulty with a new speaker, you can now start enjoying the music again through the internal speaker.
Take care.
Apr 14, 2010 | Apple iPod nano
RCA Guide Plus Gold Gemstar 27 inch Entertainment Series has perfect picture no sound. The speakers are ok have tested them. When tv is turned on and dvd player is on shows perfect picture but can only...
On the left hand side of the remote control there is a blue or diferent kind of small sercle round buton (mute) push it once and turn the volume up till you hear the volume.
Nov 06, 2009 | RCA Televison & Video
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
WS-5551 only on/off button works, won't respond to remote at all
take off the speaker grill, you will see 2 wire plugs, turn the tv on, disconnect both plugs, if it now works with the remote then you need to replace all of the front switches, or leave them unplugged and use the remote, if this doesn't work, you have a bad dm board or signal module which could get very expensive.
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Wii turns on but has no picture or sound
You could try resetting it by taking out the motherboard battery.
It is on the bottom at the back under a plastic cover.
You may need a tri wing screwdriver to remove the cover.
Try taking this out for a couple of hours and it will reset it.
Hope this helps,
Jul 04, 2008 | Nintendo Wii Console
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Remote is not working
I have the same thing. NOTE THE TROUBLE IS NOT IN THE REMOTE IN THIS CASE. It is in the control ciruits OR the power supply ciruits which operate the control circuits. [I think}. My set is "stuck" on chan. 10, I get a great picture, the volume is "stuck" where it was when the trouble occurred; I was changing the channel with the +/- controls on the remote when the trouble occured- I am not sure if I heard a sound from the set when it stopped responding or not. Now, there is no response in the set to the buttons on the set or the buttons in the remote- OTHER THAN ON/OFF. -and re. the on/off- when I shut the set off with the remote- th picture goes dark as it should pretty immediately- but there is about a 15sec delay before the sound shuts off [and the pilot light on the set goes red at that point also] I have opened the back of the set [I bought the set from a crook on ebay, it had been opened, past warranty anyway] and I MUST ADMIT I AM VERY IMPRESSED WITH THE QUALITY/CRAFTSMANSHIP I FOUND THERE. THE THING IS RATHER BEAUTIFULY/STURDILY MADE!! dOES ANYONE HAVE A SCHEMATIC FOR THIS SET OR KNOW OF ONE THAT HAS BEEN FIXTD?? DAVIDO
Mar 31, 2007 | iLO 2600 Television
LG 50PC3D 50 in. Plasma Television Logo
56 people viewed this question
Computer Repairing
Computer Repairing
