Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoints in test mode
The problem is easily solved. 1 turn appliance off at mains wait 10 secs 2 turn mains back on 3 hold down both on/off & start/cancel together 4 the symbol D/OFF appears in the display 5 release buttons. PROBLEM SOLVED !
    President:
  • 1,294 Answers
This is great!!
Posted on Dec 27, 2007
SOURCE:
What does error code E7 indicate on a bush dishwasher
E7 The appliance is waiting for a signal from a flow meter. However this appliance is not fitted with a flow meter. See below for details on how to cure this fault.
For an E7 fault the PCB has to be reset:
1. With the door open, turn the appliance ‘On’
2. Within 3 secs, push the program selection button ‘P’ 4 times
The test program has been selected if ‘Soak’ and ‘Strong’ LEDs are flashing. (This combination represents the test program for appliances that have a flow meter.
1. If the above LEDs do not flash after carrying out the above procedure, then switch appliance ‘Off’ and repeat process again
Once the above test has been activated and the LEDs are illuminated then:
2. Push the program selection button ‘P’ once to select the version “without flow meter”
bullet Check that the ‘Soak’ LED is ‘Off’ and the ‘Strong’ LED is ‘Flashing’
To complete the procedure:
1. Ensure appliance is switched ‘Off’
2. Wait for approx. 10 to 15 secs
3. Switch the appliance back ‘On’
4. Select the SOAK program to test
Nov 02, 2015 | Dishwashers
How to turn off demo mode?
Good Morning Friend,
I understand you want to turn the demo mode off of your Electrolux dryer, model# EWED65H. To deactivate the demo mode in your appliance, please try the following:
    1)Turn the cycle knob to the last cycle on the right.
    2)Press the start button and immediately afterwards press the cancel button.
    3)Within 10 seconds, wake up your appliance by pressing the start button once.
    4)Immediately, press and hold cancel and the right most key under the display, together for a minimum of 6 seconds. DEMO MODE will no longer show in the display.
    5)If a 3 prong power cord (120V cord) is attached, remove it and attach normal 240 V cord.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EWED65H Dryer
Saying test on my wt965 washer
There are few methods, depends on the age of the appliance.
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Simply press the Cancel button and the appliance returns to default.
Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
or
Switch off at mains, press and hold On/Off & Start/Cancel buttons, switch mains back on, keep holding down buttons until Doff appears in display.
Nov 02, 2012 | Hotpoint Washing Machines
Saying test on the display unit
d OFF appears.
or
Nov 02, 2012 | Hotpoint Ultima WF860 Front Load Washer
I refill the cartridge of my canon mp496 printer.I print images and everithing is ok but the ink lamps are orange .I don't know what to do ! Please ,help me !!
One of these reset methods should fix the problem
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Jul 01, 2011 | Office Equipment & Supplies
Canon error b200 in ip2700
1) Press and Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press and Hold the power button for 1 sec. this should turn the printer back on.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again. that should get you working.
Jun 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon np258 cant operate after refill
You may need to reset the ink counter. Try one of the following solutions.
THis is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon Office Equipment & Supplies
How can i reset the Ink Level on Canon MP240
Here are three methods that have worked on Canon printers. Have no fear. None of these will cause damage if they do not reset the ink counter. Once reset you will have to monitor the cartridges by weight, as the system will always show them to be full.
The first is basically a modified version posted for the MP460.
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470 to get the test sheet).
11. Open the cover.
11. Now open cover
14. Close cover
Mar 09, 2011 | Canon PIXMA MP240 All-In-One InkJet...
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Cancel button not working properly
Try a reset:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 28, 2010 | Apple iPhone 3G
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
