Question about Refrigerators
Freezer is cold but refrigerator is warm
Freezer is cold but the refrigerator is warm
  • jeffjoel2424 May 02, 2009
    When I close frezeer door the air in the refrigerator stop and when open freezer door air to much in refrigerator.
  • 170 Answers
Number one when you can always provide model number and make...it helps enormously in troubleshooting otherwise you get these long detailed threads...from an anal tech like myself.
Cold is a relative term....how cold...use a thermometer...and determine if the freezer...is at least..10-20 degrees or colder if not it is not cold enough...and here are some generic answers for that problem....I will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the refrigerator side compartment..there is usually a baffle...that controls...the amount of air-flow into the frig side...it can be adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Apr 22, 2009
  • Tisha Cobb Oct 15, 2013
    My lg refrigrator is about 4 year old, the freezer is at the bottom and fridge is on thetop
Defrost heater - reoplace with dual heaer assy - also good idea to replace defrost timer
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
Freezer is working, refrigerator is warm
You probably have a defrost issue with the freezer. Cold air is passed to the refrigerator section from the freezer, when the freezer does not defrost air flow to the refrigerator is eliminated causing the refrigerator to warm up. Check for icing on the back wall of the freezer. If no ice on back of freezer, check the damper assembly going to the refrigerator section.
May 26, 2015 | Refrigerators
Lg refrigerator getting warm
If the freezer is cold you probably have a defrosting problem.
Change youtube search to cold freezer warm refrigerator.
refrigerator getting warm YouTube
Oct 05, 2014 | Refrigerators
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Refrigerator is warm. Freezer did not frost up. Will not keep food cold. . . stays warm.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 02, 2011 | Refrigerators
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
I have a HTR16ABSARWW Top Freezer Refrigerator in
You need to warm up the garage for it to work right. The cold control reads the refrigerator temperature and if it's already cold, will not turn on the compressor. Hence the freezer warms up to the ambient temperature.
Jan 06, 2010 | Hotpoint Refrigerators
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
Refrigerators Logo
1,035 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
