Question about Intel D845GVSR Motherboard
Front Audio Problem
I can't found any port of front panel for sound device...please reply me as soon as possible..
thank you
  • Anonymous Apr 26, 2009
    i have instol the audio driver but pc is restart in.
Go to this site
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
in the last there is a manual in which the front panel connections is mentioned.
Posted on Apr 22, 2009
I have a audio interface : alesis io2express And headphone :Sol replubic I start a vocal recording and after that I listen to it but I found out the it give me a buzzing and like robotic sound I tried turn...
Sounds like you may be recording electrical interference from another electrical source as well while trying to record your vocals. Try unplugging other electrical devices that are in the area of your recording equipment, then try recording again. If that doesn't work, move your recording equipment to another location and try to record again.
May 06, 2014 | Computers & Internet
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
Front headphone jack does not work, do not get sound. I have an a1450n HP Pavilion running windows 7 ultimate. Running Realtek High Definition audio drivers. This problem is quite common on the internet....
If you face issue with only front jack then you need to check the connection of front jack to motherboard. For that open cpu cabinet cover.Then find the cable from front sound jack to motherboard. Connect it into right position .You can find diagram on motherboard or in manual.There is some pins on the corner of motherboard. Let me know if you need further assistance. Thanks for using FixYa.
Feb 28, 2011 | HP Pavilion a1450n PC Desktop
My pc have no sound i like to hear the sound fro the computer what can i do
in bios set it to default, and check for the driver installed and must no error found on device manager. if prove that the problem is in audio port, you can add on sound pci card.
Apr 29, 2010 | Asrock Motherboard K7S41GX for AMD...
Hi i am gaurav i have problem with sound.when i connect my headphones in front panel it dose'nt work.then i check the disable front panel jack detection in realtek manager.then i got i the sound but the...
Surely your headphones are working fine. So it can be either software or hardware problem.
To check if any problem with drivers, go to device manager, uninstall the drivers for audio, and reinstall a fresh piece of audio drivers. Restart the system and now check the sound. If the problem exists, then its hardware problem.
Since front panel and back panel are not working, then it can be the problem with the audio sockets of the motherboard. You have to consult a technician for that.
Hope your sounds get ok with the driver install. Thanks
Apr 20, 2010 | Computers & Internet
XPS420 Front Mic Problems
Try going to the Control Panel and select Sound and Audio Device Properties. Go to the Audio tab and under Sound Recording section make sure your device is selected.
Please don't forget to rate this solution.
Jun 08, 2009 | Dell XPS 420 PC Desktop
Front panel for sounds is not working, ports for the front panel has 5x2 ports but my audio pin only has 4x2
MY ASUS M2MN SE MOTHER BOARD FRONT PANEL AUDIO & MICROPHONE IS NOT WORKING, I WILL REPLACE A NEW FRONT PANEL BOARD, BUT STILL NOW SUFFERING SAME PROBLEM, PLEASE GIVE ME A SOLUTION ON MY E-MAIL, THANK YOU.
SEKHAR CHAKRABORTY E-mail: chakrabortyentp@yahoo.in
May 22, 2009 | Biostar GF7050V-M7 nVIDIA GeFORCE 7050...
Mic dont work
If you have one front panel and one back panel mic input port, Front panel is active by default on most systems. Try front first. if that is ok..or even if not, click on sound icon near clock (double click) select input/recording. unmute the mic or check it as input. thanks
Apr 03, 2009 | Acer (54.AA806.001) Sound Card
About my audio output
ur mobo doesent have this front panel feature.....
connect ur audio devices in the rear ports.
Feb 15, 2009 | Microsoft Windows Vista Ultimate Edition
Installation of audio driver
Check your device manager and see if the audio card is detected by the system. Usually if the drivers aren't installed, it will say audio controller with a yellow question mark or a yellow exclamation mark. If not detected, reseat your audio card if possible.
Thanks!
Aug 26, 2008 | Computers & Internet
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
