Question about Refrigerators
Freezer is cold but refrigerator isn't
Hi I have a frigidaire elite refrigerator that is self defrost. I have unplugged it and defrosted it 3 times, it works about a week and then the refrigerator stops staying cold. The freezer works, but the refrigerator gets up to 58 degrees
  • 170 Answers
Number one when you can always provide model number and make...it helps enormously in troubleshooting otherwise you get these long detailed threads...from an anal tech like myself.
Cold is a relative term....how cold...use a thermometer...and determine if the freezer...is at least..10-20 degrees or colder if not it is not cold enough...and here are some generic answers for that problem....I will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the refrigerator side compartment..there is usually a baffle...that controls...the amount of air-flow into the frig side...it can be adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Apr 22, 2009
Frigidaire Refrigerator FFTR1814LW bottom fridge not cooling properly 50 degrees. The top freezer is rock soild Thx
That is the classic symptoms of a defrost system failure. Suggest you look behind the rear panel on the inside of your freezer and see if it is iced up. If it is then it is a defrost problem which could be the defrost heater, defrost thermostat or defrost timer. If it isn't iced up, then check to make sure the fan is operating. If it isn't then it won't push cold air out of the freezer into the refrigerator section.
Sep 14, 2011 | Refrigerators
Freezer is filled with ice particles. Should I unplug and see if it defrosts?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 22, 2011 | Frigidaire Refrigerators
Frigidaire FRS22ZRF side by side. Freezer works but the Frig isn't cooling. Anyone know what the problem could be?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Jul 02, 2011 | Frigidaire FSC23F7D Side by Side...
We have a Kenmore Elite Freezer Model #253.29082994. We had the freezer plugged in and it was working fine. We unplugged it and moved it and now when we plug it in it won't start. Is there some kind of...
You refrigerator was made by Frigidaire Adaptive Defrost Controls Frigidaire Refrigerator Trouble Shooting and Diagnosing
On the initial plugin, or when power is restored to the fridge after a power outage:
If terminating thermostat is open, the fridge enters a compressor (cooling) cycle.
If the terminating thermostat is closed, the first defrost cycle occurs 1 hour
after initial plug-in.
Maximum defrost cycle time is 24 minutes.
Minimum time between defrost cycles is 6 hours. (compressor runtime)
Maximum normal clock time between defrost cycles is 12 hours.
Maximum time between defrost cycles (in "vacation" mode) is 72 hours.
Vacation mode is not entered unless the door has not been opened in at least 24 hours.
Note that the ADC will only enter the defrost mode if the terminating thermostat is closed. If the terminating thermostat is open when defrost is initiated, the ADC board will wait for six minutes and then return to the cooling mode.
ASSUMING that the fridge has been on and running,
and the terminating thermostat is closed,
defrost is initiated by pressing the door (light) switch
at least five times within six seconds.
The defrost heater should start heating up within 8 seconds.
If the above procedure caused the heater to heat up, the ADC board is probably bad; replace it.
If the defrost heater does not heat up, test the defrost heater, terminating thermostat and cold control for continuity as follows:
Unplug the fridge from the wall. Unplug the ADC board from its connector.
Test the connector for continuity between the following leads:
Defrost Heater = DEF TERM (blue) to DEF OUT (brown).
Terminating Thermostat = DEF TERM (blue) to NEUTRAL (lt blue).
Cold Control = COLD CONTROL (orange) to L1 (black).
Replace the defective component.
dvfxnxxsllnll3xsyszyldhiovfnqznnvujbtluyw2q4uxl2ntjkcdj6njhpmxnefkntwws4bi9kdg83ay5nd0jdsnhpljetrth0supsduvxugpczlkyaszhzu1onu9xwdfjv0xta0jidtfiwg%3d%3d
Apr 26, 2011 | Kenmore Freezers
Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Jun 20, 2009 | Frigidaire FRT21H8 Top Freezer...
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad. unthawing in freezer...
you have a defrost problem either a bimetal thermostat, defrost timer or a heater. open doors and unplug unit for 2 days to let defrost it will work great for a week or so. not to costly to fix either way
Feb 23, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery FRS26ZGEB - 12 years old
you have a defrost problem or damper problem or evapator fan
1) Check the fan in the freezer is running
2) defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
3) check the damper make sure it is opening and cold air is blowing
How you need to repair what defrost part failed
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Jul 03, 2008 | Frigidaire FRS26R4A Side by Side...
Problem
It has a defrost problem.  1.  Defrost thermostat  2.  Defrost timer or 3.  Defrost heater.  Let me know if you want me to walk you thru the check out.
Oct 16, 2007 | Frigidaire FRT21HS6D Top Freezer...
Refrigerators Logo
1,826 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
