Question about Dryers
No heat everything seems fine but heating up
  • 544 Answers
HI,
correct me if i am wrong your problem for your Dryer is not heating Right?
if so you can check this suggestion.
you do need a new motor.you need to take 2 screws out of top where lint filter goes. take top up and their will be 2 screws one on each side take screws out and pull upward and forward and the front panel will come off. you will need to remove belt and tub then you will see motor. you will need to be able to grab back side of motor that attaches to blower and front shaft of motor and turn opposite way to come loose from blower. you will then take back clip off and front clip and unplug motor and pull out. good luck hope instructions helped.
thanks,
Posted on Apr 24, 2009
My whirlpool dryer is not heating....has good airflow and everything else seems fine. It's an older model - kingsize.
i would say the heating element has burnt out replace it and you should be right to go
May 13, 2010 | Dryers
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
Whirlpool dryer model LER3624jq0 has no heat but spins and works fine besides that..fuses are good, the heat coils are getting electricity but just wont heat up.. seems like everything is workin fine just...
They could get electricity but when the coils are broken into the will not heat. Diaphram is at AppliancePartsPros.com I dont actually know them but I found my parts there.
Oct 10, 2009 | Whirlpool Dryers
Dryer not heating w/o indication
It's very possible that you need a new heating coil. This is an easy do-it-yourself fix if it's an electric dryer. Save all your receipts and purchase the replacement part from a business that will give your a refund (minus a small restocking fee perhaps).
May 14, 2009 | Dryers
Microwave is not cooking/heating.
sounds like the magnatron they can just go out like a light bulb easier to buy a new microwave hope this helps regards Jim
Apr 13, 2009 | Microwave Ovens
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Water heater doesnt heat up
has the unit every been cleand you can check the it in the service door
Dec 01, 2008 | Water Heaters
Dryers Logo
54 people viewed this question
Top Dryers Experts
