Question about Whirlpool Duet GHW9150P Front Load Washer
Water leak from my washer underneath i have a Whirlpool Duet Sport® HT 3.7 I.E.C. cu
  • 9 Answers
Check the filter, as it may be leaking. To do so, take white panel off the front, put a bucket in front of the unit, unseat the rubber feet holding in the white plug and pull the white plug out, unscrew it, allowing water to run into the bucket, clean filter, check the gasket, as it may need replacement (if so, replace it), then screw white plug back in, push plug back into unit, secure the rubber feet, and replace the front panel.
Posted on Apr 24, 2009
Why is water won't filling the reservoir?
check the water inlet valve with a meter for continuity
Sep 06, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
I have a whirlpool duet sport washer that is leaking from the back. we just replaces a screw that hold sthe drive motor up bc it broke. it looks ike the water is dripping by there.
Possible that the tub is cracked or there is a dent which must be checked. if the leak, is visible and comes from the tub you can use some good sealer with glue to stop the leak. this can be polished off. You also try with silicon sealing which comes in small tubes and can fix this leak.
Jun 05, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet front load washer flashing f 21
The instructions to fix this were great and did the trick, would add a few suggestions:
1) Removing the front panel just under the washer door can be tricky, it is secured underneath by 3 1/4" hex screws, you may need a special hex driver or ratchet to remove (can get at home Depot for $4)
2) Make sure you check the tubing from the drum and out to the drain they can be clogged to
3) Twist open drain filter slowly, water will come out so put a heavy duty garbage bag underneath to catch water
4) When replacing filter make sure to line up notch at the top of filter with the groove inside and then slowly screw clockwise back in until tight
5)Make sure to replace front cover tightly, there is a drip fuse that won't let the washer run unless front cover is back on.
Socks are the most common thing to be found.
All will take about 10 mins.
Mar 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a whirlpool duet sport that is overflowing from the soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 03, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
360 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
