Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
I have an older Kenmore Delux Stove and the spring ...sprung
I have an older Kenmore Delux Stove and the spring on the hing seems to be gone. I opened the door and let it drop and I think the spring sprung out. Is there a solution to fixing the spring in the door.
  • franni01 Apr 22, 2009
    What is a sound drive.
If u automaticaly fix sound driver
Posted on Apr 22, 2009
Is there a way to fix what seems to be a sprung hinge?
If you are saying the door no longer returns to its upright position on it's own than the spring broke, the hinge is fine so long as it travels the same path.
Just google: "oven door spring XXXX" where the x's are your model number.
Apr 04, 2015 | Ovens
Kenmore oven door fails to lock
1. Remove the pan drawer
2. With someone holding glass up, remove the four screws at the bottom of the door that hold the glass front to the door frame. Gently lower the panel about two inches until the side guides are below the door trim cap. Place out of the way so it doesn't fall over etc.
3. Keeping the door closed, use a spring puller to remove each spring from the hinge. (I made one out of a hanger and a screwdriver. Double thickness at the hook, wrapped and secured around the screwdriver to make a handle) If you do things this way be VERY careful. Be sure it is really strong and is not going to slip. The springs are really under tension and will shrink down about an inch from where they are hooked. (Be sure to support the door so it does not fall open when the springs are removed. It will just make things worse.)
4. After the springs are off gently open the door all of the way.
5. Pull down the hinge locks from the oven body and lift the base of the door up. This will lift the door hinges off of the mounts in the oven frame and allow you to pull the door away from the body.
6. Place the door on your box or workbench etc
7. Remove the two screws on each side of the door that hold the hinges in place. Remove the hinges.
Reinstallation is in reverse.
Hinge repair.
By placing the lower part of the hinge (by the axle) against a ruler I was able to see that the upper section was bent out on each hinge. To correct it I placed the hinge over a pair of 4x4 blocks so that it curved up in the center, and hit it a few times with a hammer. The metal was very responsive and quickly bent back into shape. Be careful here as you don't want to bend them too far. I actually went a little past true, wanting to get a little more push at the top of the door. I placed the hinges directly on the oven to see the difference and they looked good (Be sure to put a piece of cardboard or rag between them and the top to keep them from scratching the surface.
Put the hinges back in the door, screw it together and hang it back on the stove, replace the springs and the glass, and check your fit. Good luck.
Feb 01, 2013 | Kenmore Ovens
Kenmore Elite HE5t washer - Door is hard to open and close
It may be sprung in the hinge or there may be a tiny piece of debris causeing the door to hang when being opened or closed.
Jun 03, 2012 | Kenmore Elite HE5t Washer
Kenmore Elite Oasis Washer Mod #110.27082601 Ser # CT1170582. I went to put the lid down and heard a "pop" type sound, and now the lid won't stay up. Everything else is working properly, and the...
Hello Chrissym1313,
Taken straight from the APPLIANCEPARTSPROS.COM
website... (Left & Right hinge Springs)
Hi--the lid on my Kenmore elite washer does not stay open on its own anymore--from what I have read-sounds like I need new hinge lid springs--can you tell me part #'s and how I would go about replacing those--thnx!!
Mike J for Model Number 110.28082700
Answer Hello Mike. You will need to order WP8580114 and WP8580115 for the unit.
Cross Reference Information
Part Number WP8580115 (AP6013571) replaces 8563961, 8580115, PS11746797, B008DK65SA, B002M647S6, B072YYQ2TQ.
Right hinge spring:
http://www.appliancepartspros.com/whirlpool-hinge-spring-rgt-wp8580115-ap6013571.html
Left hinge spring:
Whirlpool WP8580114 Hinge Left AppliancePartsPros com
Hope this helps
Carnac the Magnificent
Once you have your absolute part numbers... Then you can go SHOPPING... (Left: on eBay $25.50 plus tax & shipping)
New OEM Whirlpool Kenmore Washer Door Hinge 8580114 WP8580114 LH eBay
Right hinge
Amazon com Kenmore Elite W8580115 Washer Lid Hinge Home Improvement
RH hinge on PARTSELECT... ($39.20 plus tax & shipping)
Whirlpool WP8580115 Hinge PartSelect
Dec 18, 2017 | Washing Machines
Oven door seems sprung as if a spring may be shot and door dose not close all the way?
You need to replace both oven door hinges, as the springs are weak, and there is no adjustment available.
Sep 25, 2010 | Cadco OV-400 Electric Single Oven
Kenmore 790.49073400 oven door won't close completely
Hello- You are on the right track. The hinge assemblies are 'sprung' or bent out of shape. Replacing them is pretty easy, so you can do it yourself. Four screws on each side. Be careful, these springs can snap closed and bite ya. Use the little pins that come with the new set to lock hinge so this doesn't happen. Let me know if this info helps- have more if needed- Thanks- Ed
Mar 19, 2010 | Kenmore Ovens
I have a Frigidaire FDB2410LDC3 Dishwasher. It was working great until my 5 year old fell on the door and it does not spring back up now. I tried looking with a flashlight in the sides and the springs...
Prhandle and latch.obably sprung the hinges. The reason it dont want to work right is the door latch is not latching properly and therefore it wont start. I would start by replacing the hinges and springs and the
Dec 30, 2009 | Dishwashers
Kenmore electric free standing range--door is sprung. How to fix.
Usually the door is ok it is generally the hinges. So order both left and right u will need a model number and here is a good parts number 1-877-262-1479 they are fairly simple to install look it up on sears.com and us can see a picture and get a good idea how they are installed
May 31, 2009 | Kenmore 99123 Electric Kitchen Range
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
108 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
