Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Bissell Proheat2x will not despence water or cleaning sollution
I have used 3 times with no problem
Have
Posted on Apr 22, 2009
How do I fix sucton on my bissell prOheat2x ?
Check the filters. There's one on the water tank cap (looks like a screen) and one under the Flow Indicator: turn the Flow Indicator Cap counter-clockwise and remove it. Lift the rotor out and the filter is under it. Clean and reinstall in reverse order. If that doesn't work contact the Bissell Consumer Care at 1-800-237-7691 Hope one of those helps.
Feb 17, 2015 | Bissell Vacuums
Bissell proheat2x won't suck
Check filters. There's one on the water tank cap (looks like a screen) and the other is under the Flow Indicator: turn the Flow Indicator Cap counter-clockwise and remove it. Lift the rotor and under it is the filter. Clean and replace in reverse order. Hope that helped. If not you could contact Bissell Consumer Care at 1-800-237-7691. Good Luck.
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat2x 12 amps dual 10 cleaning rolls does not spray water. help
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bxn
Sep 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissell proheat2x cleanshot, it will dispense water but not cleaning solution,any thoughts
heatman101
hhfkh
Nov 03, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I HAVE A BISSELL 12AMPS PROHEAT2X RUG SHAMPOO, IT WON'T PUMP OUT WATER TO CLEAN ,THE BRUSHES WORK BUT NOT ANY LIQUID. ALSO CAN YOU GIVE ME A REPAIR SERVICE NEAR THE 34219 ZIP CODE
You have to stop leaving the cleaning solution the tank after you're done...unfortunately you may be outaluck...try putting a tiny amount of ammonia in the tank and keep pulling the solution "trigger"...maybe you'll get lucky...otherwise trash the vac :o( Sorry
Jun 14, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
I have the bissell proheat2x that someone gave me i fill the water up but where is the dirty water going
heatman101
cbnm
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
189 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
