Question about Keurig B100 Coffee Maker
Can only make a cup of water without single serving in.
I have tried to make a cup of coffee several times lately and failed with only a small amount of coffe coming through and into the cup. I have to take out the coffee container and rotate it which makes an additional hole in the bottom. This seems to allow a cup to be completed every time but unfortunatly it makes a mess inside with coffee grains. I have also found that I can make a cup of hot water with no problems every time without the coffee insert. I have checked the three holes for bieng clogged and cleaned the unit the best I can with the sames results in the end.
I had similar results and figured that the outflow needle, which punctures the bottom of the cup, might be clogged. The outflow needle can be accessed by just opening the top and removing any existing K-cups. I slid a narrow, stiff wire into the needle, and reamed it out a little bit. The coffee maker now seems to work as well as ever.
Posted on Apr 26, 2009
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Flex Brew model 49983. why isn't the water dispensing on the single serve side?
Return it back to the store. I would get a different model or brand so that this problem will not return again soon. You do not have to clean it out with white vinegar after 1 week of use. Maybe 2 or 3 times a year is enough.
Nov 27, 2015 | Hamilton Beach Coffee Makers & Espresso...
My keurig coffee maker shuts off after making a small amount of coffee
You should put it through a cleaning cycle of vigner and let it stand for about 4 hour in this state. After rinse through with clean water about 3 times. The pump may need a good cleaning. I do this about once every 2 months.
Sep 30, 2014 | Keurig Starbucks Single Serving K-Cup...
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Weak Coffee
Yep, it's the one inherent flaw in the single serve machines - someone else decides what 'the perfect cup of coffee' tastes like.  Quite presumptuous, actually.
Solution I found to be acceptable:  Buy only the extra bold flavors (there's about 5 or 6 varieties) and brew using the small cup size button.  Yes, you only fill your mug about 3/4 of the way, but at least you get a decent cup of coffee.
The ONLY flavor I found to be strong enough when brewing with the large cup control button is DOUBLE BLACK DIAMOND...the rest is crap.
Dec 27, 2007 | Keurig B50 Coffee Maker
Keurig B100 Coffee Maker Logo
530 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
