Question about Dryers
Dryer belt how do you get to the belt how to open unit for repair
  • 490 Answers
Remove the front panel on the dryer there should be screws that hold it on at the bottom and clips at the top lay the unit down on its back and after screws are removed you lift the front up and the clips on the top of the front cover will come out then you can get to the belt
Posted on Apr 22, 2009
How do u put a kenmore dryer belt on do u have a diagram?
all kenmore dryers much the same procedure to change the belt
the casing has to be opened
some dissa sembly required
link as an example of how its done on any dryer unit
copy and paste link into your search engine
https://www.youtube.com/watch?v=x6zFGUpfC18
or
https://www.searspartsdirect.com/repair-guide/dryer/how-to-replace-a-dryer-drive-belt.html
May 29, 2016 | Kenmore Dryers
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
Pluged in push star says its working not working
you will need to open the dryer up and see if the belt is off or broken:
opening up a dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagram:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 26, 2011 | Dryers
I have a maytag neptue dc dryer & I need to know how to replace the belt
open the cabinet:
http://www.partselect.com/dryer+maytag-atlantis-open-cabinet+repair.htm
route the belt:
May 22, 2011 | Dryers
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
you will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
hope the helped Tim
May 21, 2011 | Whirlpool LEN2000PW Dryer
I need to replace tumble dryer belt
how to open dryer:
belt diagram:
note Kenmore/Whirlpool are the same
Mar 19, 2011 | Dryers
Drum belt installation
here are some belt diagrams, don't know what dryer you own:
http://www.partselect.com/dryer+examine-belt+repair.htm
http://www.applianceaid.com/images/belt-config.JPG
here is how to open some dryers:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Good Luck Tim
Mar 11, 2011 | Dryers
Dryer will not spin. Its a propane dryer and the heat is fine...just wont spin. I assume there is a belt somewhere?
Belt is on the inside. It wraps around the motor pulley and the drum. Opening the dryer is required. Make sure unit is unpluged 1st. Very easy repair. Belt can be ordered online and shipped to you. Model and serial number will be required. Probably about a $15 - $30 repair. Should take about 30 -45 minutes on the long side. Instruction to open your dryer should be here: http://www.partselect.com/dryer+open-cabinet+repair.htm
Feb 05, 2011 | KitchenAid Dryers
Belt broken
how to open a dryer:
belt diagram:
Jan 10, 2011 | Whirlpool Dryers
Maytag dryer model#PYE2300AYW turns on but makes loud noise when tumbling. whats wrong with it?
If it is a metallic noise, it can either be a pulley with bad bearings, or possibly the rear drum support/ bearing. If squeeling noise, possile belt. I would open the unit and check it out. Keep in mind that, in many cases, the repair can be more than buying a new unit. I bought a good, new dryer from Lowes for around $200. It would be hard to get a repair guy to come out and do the repair for that amount. Choose wisely grasshopper.
May 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
