Question about Zebra TLP 2844-Z Thermal Label Printer
My printer thinks it s out of media or ribbon but it is not. It will send out a few blanks, and then I can print something, and about a fifth through the next label, it stops printing and starts blinking red, even though there is plenty of paper and ribbon in it.
    Scholar:
  • 62 Answers
I have seen this problem a few times. The problem is occuring because the ribbon spool is popping off it's guide sprockets. Often it will pop itself back on. So when you open printer and look at the ribbon it looks fine. Solution. Make sure that the ribbon core is pushed firmly onto it's guide sprockets. You may have to push the ribbon out of the core with as the soft ribbon tends to fill the gaps in the cardboard ribbon core.
Posted on Apr 25, 2009
  • Jim H Apr 25, 2009
    Easiest way to verify whether ribbon is causing problems is...
    1: Remove ribbon from printer,
    2: Perform a calibration routine with ribbon removed from printer.
    if this works, (press feed button 6 times to verify correct operation)
    3: Install ribbon and perform calibration again. If it does not calibrate properly then know that the ribbon is causing problem.
Needs to be restarted after every print command
You can always try a tailor made driver for free at www.nicelabel.cl ( you will need to enter your data), that's how we solve ss.ss. bad drivers issues for our customers
Oct 16, 2012 | Argox R-400 Thermal Printer
I have z4mplus recently i changed print head , fonts are complete one blank line is same place for any priting
If the blank line is vertical (parallel to the print direction) then
Either the head is damaged at this point (dots missing) or you have something on the ribbon which prevents the head from doing the transfer.
Or the ribbon is faulty and you have to change the ribbon
Aug 11, 2011 | Zebra Z4Mplus Label Printer
Hi, i have a TLP 2844 printer Thermal, but i cant print labels. I have read the manual and follow the instructions. Every time i put labels on the printer, only send me blanks. Can you help me, please
Are you trying to print in thermal or thermal transfer mode? If thermal transfer mode, do you have the ribbon install correctly with the coated side facing towards the label? If using thermal mode, are you using thermal paper and are you trying to print on the coated side? Hold the feed button down and turn the printer on. Hold it down until the light stops flashing. At this point the printer will print a diagnostic dump. If nothing prints then either you have the media loaded wrong or something else is wrong with the printer.
Jul 19, 2011 | Zebra LP 2844 Thermal Printer
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
Zebra 105sl laebls always come out blank
Power on while holding the pause button for 5 seconds. This should print black bar across the width of the label. If this prints, then check the darkness parameter in your label format or driver. Also check to make sure your ribbon is feeding coated side out. There is a shiny side and a dull side to a ribbon. The dull side should be against the media. If it is leaving an image on the ribbon and nothing on the label the ribbon is either loaded incorrectly or not a zebra ribbon.
Oct 03, 2010 | Zebra 105SL Thermal Label Printer
IT PRINT A LABEL THEN SKIPS A LABEL THEN PRINTS A LABEL
You need to make sure the media and ribbon are installed correctly, and then make sure the printer is calibrated. Once you verify the media is correct, power off the printer and then back on. It should feed a few labels. Then press the button to feed again to make sure it feeds only one. If it does, then the printer is set. Now, when you go to print, if it still acts up, you need to check either the driver settings or the software settings. Label size could be set incorrectly.
Aug 30, 2009 | Zebra Eltron TLP 2742 Thermal Label...
The Zebra 11oXill printer does not stop when the ribbon is out
Yes. You need to be sure the upper Media Guide plate is installed and that you have run the Media Sensor setup that is offered through the menu. Once the setup has been run correctly, the printer will be able to sense the ribbon is miising and stop the print job. If not setup, it will do as you have described.
May 07, 2009 | Zebra 110XILL Thermal Label Printer
Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Aug 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
210 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
