Question about Dryers
Amana le8107w2 air circulation is fine but air temp is not hot
  • 73 Answers
Heater filament is either dodgy or burnt out ... if you would like to repair it yourself check Espares.com for your model and make.
Posted on Apr 22, 2009
I have a 2002 1.4 vw polo overheating. The temp gauge just keeps going up. I have no hot air coming through the vents and the bottom radiator hose stays cold but all other hoses get hot. The car was fine...
It's not likely the thermostat as they tend to stay open when they go bad; but you have no circulation when the lower hose remains cool. Most likely it's too low on coolant for circulation or the water pump is failing.
Apr 21, 2013 | Cars & Trucks
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 26, 2010 | Amana Comfort Zone 12M32PBEH Air...
Car warms up just fine but the heater blows cold air
both hoses is hot signifies thatcoolant circulation is just fine check the blend door actuator it might be stuck.pan the heater temp controller from hot to cold do you feel any change in temp of the air from the blower?if you dont feel any change check the blend door actuator
Jan 11, 2010 | 2002 Ford Taurus
Refrigerator is circulating hot air and the
Sounds like the door isn't closing properly and the light is staying on heating things up. Remove the light bulb and be sure the door closes all the way. Then see if it cools down in a couple of hours.
Jan 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The lower part of my refrigerator is freezing everything (temp. approx. 30 degrees). The upper part of the refrigerator is almost 45 degrees.
it is possible that the circulating fan is knacked. cold air drops so the bottom of your fridge so will be alot colder than the top, especially since the air will no longer be circulating.
Dec 04, 2009 | Amana ATF2136ARB 33" Top Freezer...
I'm thinking about purchasing the amana 60229 fridge, which is 35 7/8'' wide. My space is 36'' wide. I'm worried it won't fit. How much clearance is necessary?? THanks
more than 1/8" for air circulation. should have at least an inch or two all around or it will get to hot from the compressor.
Oct 04, 2009 | Refrigerators
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Nov 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Dryer LE8107W2
Check for restricted or kinked vent. Remove all lint and clean lint screen. Check for good airflow at vent hood outside.
Nov 20, 2007 | Dryers
Amana PTH153B35AK
This often happens if the unit is oversized or to close to a wall or object.
Feb 14, 2007 | Amana PTC153B35AK Air Conditioner
Dryers Logo
66 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
