Question about Irons
Breville IR20 Diva Extra Glide Iron
I have lost the instructions for my iron and want to self clean it-could anyone tell me how I do this?
4 Suggested Answers
SOURCE:
SOURCE: Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Posted on Jan 16, 2008
venexcsd
  • 1185 Answers
SOURCE: I need to descale my iron Do I just fill and dial self clean?
Fill it , turn it to max heat hold it over a sink and press the steam button
Gently move it about and scale should come out of the base
If not I use a diluted kettle descaler as the fill and then allow it to stand for a few minutes on a grill plate before doing the clean routine
A lot of gunge comes out so be prepared to wash it off with a wet cloth as it appears
Posted on Nov 16, 2009
hmerchant110
  • 7191 Answers
SOURCE: lost my self cleaning instructions, please help
You can download the complete instruction manual in PDF format by clicking this link.
The detailed steps for self-cleaning procedure is given on page 6 of this manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Posted on Jul 16, 2010
I've lost my instructions for how to clean my self cleaning iron, need step by step instructions.
Heat to highest Heat level , then press self clean button on the iron
Mar 17, 2015 | Irons
Breville VIN 214 iron leaking - can anyone help please
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
  4. God bless you
Apr 04, 2013 | Black & Decker Prestige X805 Iron
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
How do i self clean a breville iron
pleasle use the owner manual for see the self clean. download from www.fitness.manualsonline.com or www.retrevo.com and proceed accoridng.
God bless you
Jul 22, 2012 | Breville Power Steam VIN208 2400 W Steam...
How do i use the self clean on my breville steam iron 2400 technique
please refer to the owner manual for use. download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
Lost my self cleaning instructions, please help
Jul 15, 2010 | Rowenta Effective DX1900 Iron with Auto...
How to use the self clean feature on a tefal steam iron
I cleaned mine with alcohol and clean terry cloth. Took some work but it eventually got clean.
Dec 24, 2008 | Irons
Dec 23, 2007 | Irons
Irons Logo
178 people viewed this question
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
