Question about Renault Dauphinoise PTT French Post/Telephone Van
THE FLASHING LIGHT ON THE DASH BOARD WILL NOT STAY ON ONCE THE KEY IS IN THE INGITION HENCE THE VAN WILL NOT START
    Problem Solver:
  • 5 Answers
The key is at fault, on mine the push bit is missing on key and when dirt or dust get in it the light flashes to resolve i simply blow off dust or wipe off put key back in and it works every time it took me months to figure that out good lukk
Posted on Sep 25, 2010
Ingition lights not working when turn on key hiace van
Hi I'm just wondering, In most cars you can turn the dashboard lights down....
Mar 22, 2016 | Cars & Trucks
Chevy Venture Van 2007 air bag light coming on dash board while driving
That means there is a fault in the airbag system. Every time you start the vehicle it will do a self check. If the self check fails the light will stay on.
You will need a higher end scan tool to pull codes from the airbag module. Once you know what codes are present you will have a better idea of what direction to head into.
Post the codes in the comments below and I'll do my best to help you figure it out.
Feb 27, 2015 | 2007 Chevrolet Venture
Security light on won't start
Hi Eric
I think the best point to start with is to try another
key ( if you have a spare one), if the spare key didn't
work too that means you have a problem with the
immobilizer system
Jan 15, 2014 | Plymouth Cars & Trucks
2002 pontiac montanna van will not start.security light is flashing on.might be in theft mode
Yes the flashing light means the module did not read the chip in your key as being the right one for the van.
Could be the key, the sensor in the lock cylinder, or the module.
Aug 28, 2012 | 2002 Pontiac Montana
I have a 2000 chevy vernture warner bros edition i just hooked up a new cd player in my van and now it wont start and the security light is flashing can someone help me plz
was the factory's stereo what you removed? if so it has set a security code. you can try resetting the security system. STEP ONE: turn key to start position and let it come back to run position. STEP TWO: let the key stay on in the run position until the security light stops flashing.STEP THREE: once the light quits flashing turn key off then repeat steps one and two again. note: it may take up to 30 minutes to complete the reset process, after third time the van should start if not you may have to take it to the dealer to have the BCM reprogrammed.
Aug 02, 2011 | 2000 Chevrolet Venture
2001 aurora won't start at all. Hook batery up horn horn sounds and doesn't stop head lights stay on but nothing happens when the key is inthe ingition. No clicking or anything at all. alarm on...
The security system does not disable the starter, it only disables fuel to the engine. In the fuse block under the hood, locate the STARTER relay. Place your hand on this relay and see if it clicks while someone else turns the key to start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
Jul 11, 2011 | 2001 Oldsmobile Aurora
Someone attempted to steal my 1998 Savana Conversion van, I had the steering column replaced and now it still won't stay started, and a security light is on the dash board. Is there a fuel pump reset...
Hi, the security system has to learn the new key resistor in the new column. If you try to start it, leave the key on for 10 mins, the security light will go off. Turn the key off, try to start it again, and release the key. The light will come back on again. Wait another 10 mins, intill the light goes out again. (leaving the key on). This has to be done 3 times total of 30 mins. When the light goes out a 3rd time, the vehicle should start, and run. Remember to turn off the headlamps, heater, radio, etc... as they consume power, and you do not want to kill the battery. Good luck...Coop
Dec 24, 2010 | 1997 GMC Savana
I just got a 1998 PLY Voyager 3.3 o.d. trans. 1. Problem lights blink on & off on rear wiper buttons.2. head lights stay on after i turn off engine day or night.3.Doors a jar dash light stays on.4.air...
Problem #1 The blinking lights in the rear wiper rear defrost area can be reset by holding 2 buttons of the 3 on the left hand side. The top and bottom buttons. Turn the key on and hold them for about 10 sec and they should start flashing differently. Just let it do this. After they start flashing different. It will take 5 to 10 mins. Then one or more will quit flashing all together. If they don't after about 20 min reset them again it can take about 5 trys sometimes before they all go out. Also to fix the dash going out try this. This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pins you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. This also may fix the ABS light and the airbag light. Hope this helps I have done several of them.
Feb 18, 2010 | 1998 Plymouth Voyager
1997 dodge carvan engine 3.3 was running well
does it try to turn over if not it could be that the battery is dead if that not it then you mit have a blown fuse
Mar 01, 2009 | 1997 Dodge Caravan
Renault Dauphinoise PTT French Post/Telephone Van Logo
97 people viewed this question
Top Renault Toys Experts
xxxxxx xxx
Michael Sigmon
Level 1 Expert
Are you a Renault Toy Expert? Answer questions, earn points and help others
