Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e-studio 207 "local device communication error
Hey guys, I'm having a bit of trouble as well with installing the Toshibae-Studio 207 digital copier. When I install it on a PC and share it outvia GDI to a remote PC, the remote PC connects well and prints. when i share the printer over the LAN net work it installs well but when i print from a networked computer the remote pc that hosts the digital copier returns a Printer error: "Local device communications error" and No cassette with paper of the size requested is available, Click "Retry" to use paper from cassette 1 or "cancel" to abort print job". I checked all the security settings(Windows XP) and no firewall or any other security settings preventingit from happening. I needsomeones help urgently joshua
  • 3 more comments
  • arasajoshuu Apr 22, 2009
    I did that and it printed from the host pc bt the printer error: "local device communications error" still appers is there some system settings resitricting communication via lan?
  • arasajoshuu Apr 23, 2009
    wil give it a try
  • arasajoshuu Apr 24, 2009
    hi didi2005, gave it a try n still the printer error: "local device communications error"still appears on the host pc when the remote pc sends document for printing. might there be a way around it. maybe setting the mfp on a (com)port rather than lpt brings the error! any new ideas.
    hi did2005,
    i did as u mentioned and printend as instructed bt again printer error:
    "local device communications error"came up on the host pc when the
    remote pc send a document for printing. could it be the issue of
    installing the printer using a com port rather than LPT port. any new
    ideas?
  • arasajoshuu Apr 25, 2009
    am installing on windows xp os. i installed the usb first and it created a com port by its self. then installed the driver. the problem comes when printing via network, i dont have a printer kit.
  • Toshiba Master
  • 628 Answers
On the host pc that connected to the MFP, check the paper size setting under the driver properties.
Posted on Apr 22, 2009
  • didi2005 Apr 23, 2009
    If host pc working, what u need to do is to share out the printer under host pc, no need to install driver on remote pc. Then under remote pc, click run, type "\\IPaddressOfHostPc" and press Enter, u should be able to see the shared out printer. Just double click it to connect to it. ( host pc and printer must ON ). Then u can perform printing using that driver. *make sure host pc & remote pc are under same network.
  • didi2005 Apr 25, 2009
    As far as i know, this model only support usb interface, unless u has the printer kit. What kind of OS your pc is running?
    For window xp, usb driver need to be install 1st b4 proceeding to install printer driver.
What does call for service F 070, in toshiba e studio 230, refer to ? How can I solve the problem?
Toshiba Studio 230 Error Codes
Toshiba e-Studio 230 Error Codes Code: F070
Code
F070
Description
Communication error between System-CPU and Engine- CPU
Sep 30, 2016 | Toshiba E-studio 230 Multifunction Copier
How to reset Toshiba e studio 207 photo copier c46 error
e studio 207 model only have c41 to c45. there is no c46 error cord.
May 03, 2016 | Toshiba Office Equipment & Supplies
E03 error in toshiba e studio 207
Power-ON jam:
The paper is remaining on the
paper transport path when power is turned ON.
1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the MAIN board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are open circuited.
4) Replace the sensor.
5) Replace the MAIN board.
Mar 15, 2016 | Toshiba e-Studio 207 Copier
Toshiba e studio 207 error code c 97
toshiba estudio 207 copier c-56 code error solve this problems
Jan 22, 2013 | Toshiba e-Studio 207 Copier
How do i set up the toshiba e studio 207 to fax i installed a phone line but it gives me a txt error when i fax.
the only thing you have to do is set the country code if you can let us know in what country i can tell you hoe to do it
Mar 10, 2011 | Toshiba e-Studio 232 Black and White...
Got it. There was a setting on the router which blocked remote users to share files. Changed a lot of settings and not sure which one actually allowed it but working fine now. Just remember to restart the pc after each setting 'cause the settings doesn't take immediate effect. Also try installing it on a different pc and make sure that all the firewalls are off as well as any other security settings set to low
Jul 15, 2008 | Toshiba e-Studio 232 Black and White...
TOSHIBAe-STUDIO161 SOFTWEARE
Connectivity software is available though Toshiba's website.
Jun 08, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-Studio 232 Black and White Copier Logo
1,009 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
