Question about Intel Motherboard
MSI PC alert 4 program shows systems temp to hot
The MSI PC alert 4 program shows that my systems temperature in my KA780G Mobo is at 256 .F (128.C) but the board doesn’t feel that hot ,and my CPU Tem is 36C ( 96.F)
thanks
Jorge
  • 87 Answers
One of your sensors have gone haywire. either update your bios or switch the option off
Posted on Apr 22, 2009
Plugigng of wire in board
I am not entirely sure what you mean by "plugging of wire in board", but the link below takes you to the MSI website page dedicated to this board, and from here you can download drivers, manuals, specifications etc.
http://uk.msi.com/support/mb/KA780G.html#down-bios
If the information you require cannot be found here then I'm afraid its direct contact with the manufacturer.
Good luck
Aug 12, 2014 | Major Brand 1GB DDR2 667MHz DDR2...
Tip
How can test Laptop?s temperature and temperature should it be at?
<p><span>If your laptop is not working ideally it may be the cause of temperature. But most laptops naturally run hot, so a system utility that can access your laptop's internal temperature sensors can help you decide if you need to take some steps to keep your laptop cool down.</span><br /> <p><span><span> </span></span><br /> <p><span>Most CPU's maximum temperatures are around 100 degree Celsius. But you can look up temperature specifications for your specific laptop's Intel or AMD processor. Optimal operating temperature is 50 degree Celsius or below.</span><br /> <p><span> </span><br /> <p><span>Some programs will help you to test your Laptop's CPU Temperature that can show you the CPU temperature as well as other system details such as processor load, voltage, and more. And some of them can also automatically adjust the speed of your laptop's fan for better performance.</span><br /> <p><span> </span><br /> <p><b><span>Speed Fan</span></b><span>- In the case of monitoring fan speeds, voltage, and processor temperatures using your laptop's internal sensors, Speed Fan can also access S.M.A.R.T. information to set your hard disk's temperatures.</span><br /> <p><span><span> </span></span><br /> <p><b><span>Real Temp-</span></b><span> The real temp is specially designed to monitor temperature for all Intel single, dual, and core processors. In the case to showing the temperature and load the processor, it also shows the CPU's safe maximum operating temperature and how far from this maximum temperature your processor is running at. Another most important feature of Real Temp is tracking of your highest and lowest temperatures since you opened the program.</span><br /> <p><span> </span><br /> <p><span>These tips may help you to determine the exact temperature for your laptop. </span><br />
on Dec 24, 2010 | Computers & Internet
Laptop cooling fan running at very high speed
Try loading and using a program called speedfan to control your fan speed if that is appropriate. This can also show you your CPU temperature (if you can figure it out). Core Temp can show you temperature of modern CPUs, amongst others.
Otherwise try cleaning you CPU of dust - search the internet as to how to this safely.
18.April.2014
Feb 05, 2014 | MSI pr600 fan
System Temp for K9a2vm - fd
System Temperature around 86 degrees Fahrenheit. (30C)
CPU Temp replies on what CPU it is.
http://www.msi.com/service/faq/2268.html
Regards,
joecoolvette
May 02, 2013 | MSI COMPUTER K9A2VM-FD Motherboard
How hot should my onboard CPU temp. Run at and when is it to hot
40-49 degrees celcius (104-120F) is normal temperature for most systems. It is not uncommon to see higher temps when doing process intensive programs such as video games or encoding.
Sep 19, 2011 | Dell Computers & Internet
MSI VR420 notebook computer fan only works periodically, is there something aside from replacing the fan to ensure it always runs?
The fan is connected to an on board system controller and only comes on when the CPU gets hot .If you are worried you can down load a program called speed fan or find other free temperature monitoring programs to check your computers operating temperature.
I hope this helps
Andrew A
Mar 29, 2011 | MSI VR420 Notebook
MSI Motherboard: weird beep code, doesn't work with graphics card
The beeping that you hear are bios codes. These codes are designed to tell you what is wrong or at least point you in the right direction.
It is helpful to list the bios that you are using so that you can find the codes for your bios. here is a site that could be usefull to you and one of the codes that you mention say to reseat the ram or replacing the CPU.
http://www.pchell.com/hardware/beepcodes.shtml
Nov 08, 2009 | MSI KA780G AMD780G Socket AM2+ Motherboard
MSI k9ag neo2-digital shows motherboard temperature110-120Celsius
In my computer , I not give administrator password ( No password )
May 01, 2009 | Computers & Internet
Fan in my Dell desktop PC runs at very high speeds from time to time
Check your manual for instructions to see if CPU temperature monitoring is done in that system.
You may be able to view that actual operating temp. of your processor.
If that system is so equipt, then it is very possible that the fan speed is regulated by temperature and it will vary according to ambient and internal temperature to conserve a tiny bit of power.
If nothing else, you can block airflow into or out of the system box to see if the fan speed increases after a few minutes.
Blocking the exhaust in the back of the unit will probably be enough.
NOTE: DON"T walk away if you decide to experiment - you may fry some chips and those don't taste good at all!
May 06, 2008 | Dell Dimension 4700 PC Desktop
Intel Motherboard Logo
188 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
