Question about LG DR787T DVD Recorder
Dvd makes strong playing sound. normal?
It is a 5 year old LG dvd
makes loud noise from the disc slot
  • 4,889 Answers
From the info you have given, your player is probably running a few degrees hotter than usual. This causes the fan to spin at a faster than usual speed causing that noise. It can happen if you keep your player in an enclosed space blocking the heat vents from dispersing the heat. Make sure that you place it in a location where it can disperse heat more easily. This will hopefully resolve the issue.
Posted on Apr 22, 2009
Have an LG fridge about 10 years old... makes a loud buzzing noise occasionally. Fridge seem to be running fine.. Thoughts??
Dear Sir
I think this abnormal buzzing sound coming from you
Compressor inside thats creating the buzzi sounds its normal. After a long time used it can possible. Neednt to worry
Hope answer the question
Jul 19, 2016 | LG Refrigerators
The player makes a terrible noise when trying to play the disc. The disc wont load
I will strong recommend you to go to the repair shop TV for fix.
the reason is there many servomechanism inside that need LUBE , or replace gear broken or worn, or belt worn.and shaft needed lube and adjust it.
However see the flowchart.God bless you
7_21_2012_1_55_31_pm.gif7_21_2012_1_55_50_pm.jpg7_21_2012_1_56_03_pm.jpg7_21_2012_1_56_41_pm.jpg
Jul 20, 2012 | Televison & Video
My new C6900 Blu-Ray plays great, but when reading the DVD it makes a loud clunking noise. i have tried both regular DVD's and a Blu-Ray with the same results. I have a $39.00 DVD player that does not make...
Check the under side of the disc to make sure it is not scratched, if okay! what you are describing is a mechanical issue and should be checked out, because that is not normal and could indicate trouble ahead, this where your warranty comes in handy.
Jan 14, 2011 | Samsung BDC6900 3D Bluray Disc Player
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
DVD's won't play
I have a somewhat similar problem, but wasn't after a cleaning disk use. Most of the time when I try to use this system now, after I put a DVD in, I start getting a loud buzzing noise (almost as if gears are meshing)
Nov 17, 2008 | LGDVT418 System
LG home 5 disc dvd changer
defective call customer support or bring it back to were you bought it
Jul 21, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
Loud noises
Depending on the age of the system, replace or ignore.
Its your DVD drive, unfortunatly most drives are noisy -FACT- so sometimes you have to just live with it- check the back ,if manfactured in 2005 ( a lot of bad drives from this year) might be worth ringing microsoft to see if an exchange is possible.-
But if its not showing any loss of play/loading or scratching the discs - or showing error- please place disc in a xbox 360 console...You may just have to put up with it.
Jan 24, 2008 | Microsoft Xbox 360 Console
LG DR787T DVD Recorder Logo
199 people viewed this question
Computer Repairing
Computer Repairing
