Home | Nikon | D80 Digital Camera with 18-135mm Lens | Nikon D80 error
Nikon D80 Digital Camera with 18-135mm Lens
Problem for Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 error
By Sutt on Sep 23, 2007
After using our new D80 for a couple weeks with no problems, we started getting an error msg in the control screen: a flashing "F--" The manual says that this indicates either no lense attached (obviously not the problem) or a non-CPU lense attached - which aslo isn't the problem, as it's a Nikon lense which was supplied with the camer. I was able to get it to stop by turning the camera off and taking the lense off & resinstalling it. But this only worked for about 3 more pictures before the error returned. Help!
Same Problem
May 22, 2009
-   My D80 will not take any pictures. It would take a few when I'd turn it on and then off, and take the battery out- but now.... it is like I'm not even trying to take a picture. It shows on the switchboard: FF-- and r11. What do you suggest me doing, or what does the issue seem to be? Thank you for your time.
Marthalee* -   Guest
Apr 26, 2009
-   Nikon D80 with a 18-200mmDX lens- built in flash will not work or open and when shutter is pressed an r05 appears. Everything else works but I cannot get the flash to open and work. I have tried the usual ranging from cleaning to battery changes etc. Any thoughts? -   erling397
Mar 30, 2009
-   I have the same problem...The AF stopped working after a few weeks of the F-- problem. Exchanged the lens for a brand new one and now I'm having the same F-- problem. Also, spots on my pictures you can see on all blue sky shots, cleaned the lens and filter and still had spots.
R05 code?????
Help please
-   snowride
Dec 23, 2008
-   I've had the same problem, after the camera worked perfectly well for about a year (I'm using the D80 with the 18-200 VR lens). Haven't had a chance to try cleaning the contacts yet. Hopefully that will fix this maddening intermittent problem.-   RadmanDragon
Jun 09, 2008
-   I have the same problem. Is there a fix yet?
-   Razpewton
Best Solution
posted on Jun 01, 2008
Helpful)
CanadaBruce
Rank: Wiz  Nikon Expert
Rating: 81%, 52 votes
The CPU contacts on the lens can sometimes get dirty and they can be cleaned by gently rubbing them with the eraser end of a pencil.   Be very careful to not get any of the eraser rubbings into the lens.   Also, when handling a lens, don't touch these contacts, as the sweat from our hands is not good on the metal.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Sep 25, 2007
Somewhat Helpful)
Nikonian
Rank: Apprentice
Rating: 82%, 11 votes
As we can read on several forums on the Internet, the plastic bracket on the 18-135 kit lens sometimes get bad connection to the camera house. Affortunately this also can accour when using some other lenses, as Tokina and other Nikkors.
Try to demount and re-attach the lens and it should give effect. Otherwise, go back to the dealer and ask for a new one. They should know about the "problem".
Per
Sweden
Was this helpful?
Yes
No
Solution #3
posted on Jan 25, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I also get this problem but keep your lens attached and just turn it slightly one way or the other and it should automatically fix itself.
Solution #4
posted on Mar 10, 2008
Helpful)
Paul319581
Rank: Wiz
Rating: 82%, 91 votes
Try cleaning the contacts !!
and the lens !!
may be dust is there in between..
or u may give the lens for service. its also caused when the alignment of the lens is gone !
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jun 17, 2009
Somewhat Helpful)
Pablo_uk
Rank: Apprentice
Rating: 75%, 1 votes
I have the same trouble with my D80 and 18-135. I've noticed the because the lens mounting ring in this lens is plastic, its comes away from the body when you are supporting the lens with your hand and in doing so the contacts are no longer making contact with the body. If you hold the lens and pull gently, you can actually see it moving and exposing the contacts. I've spoken to Nikon and its going back under warranty
Was this helpful?
Yes
No
Solution #6
posted on Jun 28, 2009
Not Rated)
Idiot thomas
Rank: Guide
Rating: 80%, 3 votes
YES IT WORKED. JUST CLEANED THE CONTACTS WITH AFTERSHAVE!!!
Was this helpful?
Yes
No
Solution #7
posted on May 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
having a similar problem and only taking pictures outside when not zoom in. i did everything, cleaned the contacts and still having the same error.. please help
Solution #8
posted on Apr 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I was having this problem with 18 to 70 lens, F- - I removed the lens wiped the contacts and turned it in its mount a few times. Problem now gone.
Popular Solutions for Nikon D80 Digital Camera with
Questions and Unsolved Problems for Nikon D80 Digital Camera with
Do you recommend Nikon D80 Digital Camera with 18-135mm Lens?
Answer
Answer
I swapped out lenses on my Nikon D80 and now it won't take pictures. I get an rEE error message when... (More)
Answer
err displays in the screen when the camera is turned on
Answer
I have a Nikon D80 and it will work in all modes with my ae lens but only outside and manual with my... (More)
Answer
when I press the shutter release, the shutter stays open until I turn the camera off. I end up with... (More)
9 Other Users Have The Same Problem - Continued
Comment by handtoeknee, posted on Apr 20, 2008
i have the same problem with my d80 i have had it for one week. ive removed the battery removed the lens and it still has not solved the problem please help
Comment by polly ann, posted on Mar 28, 2008
i have a nikon d80 with a 18 -200 zoom and i cannto get this to work in A mode mostly. if will take 1 or 2 shots at f5.6 and then give me the error message of f-- it will not change the apeture on the sub command dial and sometimes will work once if i turn it off and on but not usually. this was so expensive it is really annoying! ann
Comment by Gandut_Slimz, posted on Feb 19, 2008
my problem is.. the error flashes "ERROR".. is this got to do with the software problem???
Comment by LisaArm, posted on Dec 10, 2007
I get this same problem all the time, the only way it starts working is if i take out the battery and leave it alone for a day or two, it really bugs, because when I "NEED" my camera it is not available, is there anymore suggestions?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D80 Digital Camera with...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
