I want to download windows vista for my acer aspire 5100 with all its complete drivers
This is the download page for your acer aspire 5100 http://www.downloadya.com/files.php?cat=84
Http://support.acer-euro.com/drivers/downloads_gd.html
here u can get all drivers by providing your model numer...
SOURCE: Cannot get through internet via ethernet, I Appreciate your help.
You didn't state what kind of net connection you are using, dial-up, cable, sattelite.
If, for instance, you have cable, is the modem connected directly to one computer, or several, via router and ifso on the router is it "wireless" or cable connected?
If you are using anything OTHER THAN dial-up, I recommend, that you unplug the router AND modem, look for "resets" on both, sometimes the reset will look like a small resessed pin that must be pushed on with a pen or toothpick.(hold down for 30 seconds) Leave them unplugged...I would advise 5 minutes, then reconnect cables and power supplys and try again.
If none of this works and you have had electrical storms,(and sometimes wind damages cable if pole mounted) you may have surge-damaged routers/ and or modems. I usually have to reset mine after every lighting storm, and had to replace a damaged router twice. Sadly on another note, I would not recommend vista to anyone, I would however recommend XP media center for computers that have specs for it.
Hope this will help.
SOURCE: NO AUDIO DEVICE INSTALLED
I am sorry i got the numbers turned around..... let me get you the right driver.
