Question about GPS
Ihave two Maxon 100G radioes that are missing the PTT switch circuit boards they are a plug in type. where can I find this part
  • bobolink908 Apr 22, 2009
    I will check this site I am sure it will help
    Sergeant:
  • 199 Answers
Http://72.14.235.132/search?q=cache:RhsJ3TxdamAJ:www.earshotcommunications.co.uk/PDF/Starcom/Brochure2006.pdf+part+Maxon+100G+radioes+PTT+switch+circuit+boards&cd=1&hl=en&ct=clnk&gl=pk
this site will help you please visit it
Posted on Apr 22, 2009
Sx700 continuous transmitt
PTT short circuit, remove the short
Jan 30, 2014 | Motorola Walkie Talkie 2-Way Radio
How to repair a motorola rdu2080d PTT button
If the push to talk button is damaged. You will need to disassemble the radio to get to the circuit board. The PTT is usually surface mount soldered to the board. You will need silver electronics grade solder, a flux pen, a solder sucker or solder wick, a replacement PTT, a soldering iron 25 watts or greater, screwdrivers to match the screws in the casing during disassembly, a table mounted vise to hold the circuit board during repair/ soldering, a very fine grit sand paper to remove any oxidation off the terminals of the PTT for a perfect solder connection, and probably a magnifying glass to inspect the new solder connection with the PTT to the circuit board.
Most of the soldering tools can be purchased at radio shack.
if you have no experience soldering, I recommend going to YouTube and watch the videos posted on DIY soldering to get a good understanding of the whole process from start to finish. There is a huge amount of informational videos on the subject there. I could sit here and try to explain the whole process and why but as the saying goes a picture is worth a thousand words (but a video is worth a million ).
Hope this helps. Have an excellent day.
Mar 25, 2012 | Motorola RDU2080d Two Way Radio
Makes loud tone when pushing ptt button
The ptt switch or circuit is not disconnecting the audio circuit. Open the unit up and check the wiring, interconnect plugs for something shorted not canceling the receiver audio.
May 10, 2010 | Radio Communications
Need a part for a maxon pm150
try phoning gb comms on 01388 778368 they repairs taxis radios
Mar 29, 2009 | Radio Communications
49-F5
Your M/C is generating RF(radio frequency) energy from the electrical system. I wish I could tell you exactly where the problem is but there are to many places that could cause this problem. some possible problem areas are the alternator, spark plugs etc. You might consider upgradding to a set of newer radios. this may be cheaper than trying to figure what area of the M/C is generating RF Energy
Aug 28, 2008 | Maxon 49-HX 2-Way Radio
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
Squelch when keying ptt
I would check my ptt wiring making sure the button is set so that when you push it it switches you from RX to TX. If you have a wiring diagram that would be helpful if not are you able to get one? In any event make sure the wires are not misconnected.
Sep 12, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
GPS Logo
27 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
