Question about Saws
Spindle that holds the blade is moving in and out
  • jlangan74 Apr 23, 2009
    Brand - RYOBI
    model number ETS 1825
  • David Ford
    David Ford May 11, 2010
    what is the brand and model number. It could be a couple things but let me look before guessing.
  • 25 Answers
This can have several causes, possibly one or both of the bearings have worn out. They may just have to be replaced. Without knowing the model,and make there are a few other possibilities.
The housing holding the bearing in place could have worn away, causing the spindle to move back and forth.
There is one other option less likely though, the outer bearing may be held in by a snap ring. If that has gone missing for some reason the spindle could have your symptoms.
Posted on Apr 22, 2009
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
How to lock armature whilst changing blade
from the upper side of spindle you could hold the shaft from moving to replace blades
Aug 08, 2013 | Garden
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
Blade is slipping, whole spindle is slipping, could barely get blade off slips when i try to saw
From the description it sounds to me like the bolt holding the blade in place isn't tight enough, obviously. If there isn't a button on the saw that stops the blade from rotating when you're changing out the blade. Try this--when tightening down the blade, put it on the saw, then open the guard and rest the blade on a piece of scrap wood to stop if from moving. Then fully tighten down the bolt that holds the blade in place and you should be fine.
Jul 30, 2011 | Porter Cable 12821 7 1/4" 40 Tooth 5/8"...
I've borrowed a circular saw (v old B+D 1 HP model). Can't loosen spindle bolt to remove blade: the blade is locked with a pair of locking pliers against the guard, but when I turn the spindle bolt...
you just have to look for little button close to blade, smash it, hold it while you move the blabe till gets stuck then you're ready to loose the blade! hope this help
Jul 24, 2011 | Saws
I'm having problems replacing the blade on my Hitachi C10FC2 miter saw
it should have lock button some wear on it push it in. this will keep the blade from move. so you and take the blot off
Jan 18, 2011 | Hitachi C10FCE2 10" Compound Miter Saw
How to engage spindle lock?
The spindle lock should be a short rod that sticks out on the motor side of the saw. Push this in and rotate the blade until the rod pushes in and locks the spindle. This will hold it tight so you can use a wrench on the nut that holds the blade on.
Sep 10, 2010 | Craftsman 13 Amp 714" Circular Saw
How do you change the blade on a GMC 10 inch cmpund miter saw?
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
Sep 10, 2010 | Makita 10" Miter Saw LS1030N
Replacing the element in a NEFF U1721 but having trouble
To rtemove the nut, hold the fan blades,and at the same time undo the securing nut clockwise as though you were tightening it, as it is a left hand thread, and vice versa for tighteming it again
Please rate mhy solution.
Thankyou..
Jan 15, 2010 | Neff U1721 Double circotherm Electric Oven
My Swisher Rough Cut 12.5 HP 44 Inch mower - The blades stop cutting when I hit a dense patch of grass. The belt and the pully are still moving at normal speed but the blade slows. Also I can spin the...
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Aug 13, 2009 | Swisher 44-Inch 12.5 HP Trailcutter...
Saws Logo
55 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
