Question about ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
A USB mouse will work but the PS/2 mouse failed. What causes it?
There are only two(2) USB port available on board and the system is prompting me to use the other high speed USB port available on board. Will an external 2 port USB do? What connector will i use to connect the ext USB ports to the board? I checked for a loose connection on PS/2 but found none. Updating driver also did not work as the system refuse to. No problem with the PS/2 keyboard. Thanks
    Brigadier General:
  • 6,966 Answers
Re: A USB mouse will work but the PS/2 mouse failed. What...
Hi melch, On the PS/2 mouse, chances are that the surface mounted fusible link/resistor supplying the +5VDC is open. It is normally very near the PS/2 port and marked [0] or labeled F???. This can be verified by measuring the absence/presence of +5 at pin 4 of the connector. In some cases, it is the I/O chip that gets damaged. Re "only two(2)USB port" aside from the 2 rear USB ports, the Asus CUV4X-C has another pair of USB connectors that are normally connected to the front panel of the casing. It is located very near the motherboard battery. Re "...prompting...high speed USB port...", normally by updating your OS (say XP to SP2) or downloading/installing latest VIA 4 in 1 Drivers should make your USB 2.0 compatible. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 23, 2007
0 characters
3 Points
My friend has an hp he bought - one or two years ago, everything works fine except the mouse and keyboard ports are all messed up from the cords being ripped out and put back in, is there any way to just...
Try the keyboard and mouse on anothe system. if it works fine the on board PS2 port is most likely bad. Buy a USB keyboard and mouse in plalace of the PS2 keybaord and mouse or change the motherbord. If the keyboard and mouse is bad replace with a good one.
Sep 28, 2010 | HP (D7580-60003) Motherboard
In the board sata port is avaliable
No SATA port is not available with this motherboard, however there are 2 IDE ports available
Following is te details of he ports:
• Up to six USB 2.0 ports
— Four ports routed to the back panel
— Two ports routed to the USB 2.0 header
• Two IDE interfaces with Ultra DMA-33 and ATA-66/100 support
• One diskette drive interface
• One parallel port
• One serial port
• One VGA port
• PS/2* keyboard and mouse ports
Jul 17, 2010 | Intel D845GVSR Motherboard
Upgrade to windows 7 caused a heap of problems
Have you tried other USB mouse?
It might just be a problem with your USB mouse, the other thing is you can also try plugging-in USB devices on your USB ports to test them like (USB flash drives)
You can also try to use PS/2 mouse to check if the problem is really the ports.
With regards to the drivers
It seems like you need to download those.
Because even you downgraded your system to XP, still the OS needs the driver for them.
Ad for the DVD drives problem
YOu can try to open up your CPU
then reseat the cables for the DVD drives.
Mar 01, 2010 | Motherboards
PS/2 mouse port not working?
Hello fredbeer,
Besides the obvious checking with your device manager, you can download a port test kit HERE. That will be able to test if it's working. The other thing you can do is switch the keyboard into the mouse port and the mouse into the keyboard port. You should get some errors, if not, one of them will work and the other won't. Hopefully, you'll get the keyboard in the mouse port to work, so you know the port is working. Also, if you have any other PS2 devices that you can test it with.
Good Luck and don't forget to leave a rating based on my solution.
Apr 15, 2009 | ASUS A7N8X-X Motherboard
Mainboard does not recognize the PS/2 mouse
Sounds like the serial port died. I have seen that happen before. You could try a DB9 to PS/2 adapter or DB9 to USB. The DB9 to PS/2 is cheaper of the 2.
Hope this helps.
Mar 01, 2009 | Shuttle HOT-591P (MB591P) Motherboard
that means you didnot clone the system yourself and it will be difficult for you to fix it. so get USB mouse and keyboard. thats the only solution for now unless you can talk it to a qualified repairer in your area.
Dec 15, 2008 | Motherboards
Mouse Doesn't Work in PS/2 port
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
Ps/2 port
if your board is still under warranty then ask for replacement.
there are available converter in the market. look for usb-ps/2 converter.
Feb 26, 2008 | Gigabyte GA-8I945GMF Motherboard
Ps/2 keyboard port not working
Slim, Other than saying well it was a good couple years for the board lets just verify: Have you tried a different keyboard? Check device manager and see if you uninstall the keyboard and then reinstall it. Or have you recently installed any new devices that may have taken the resources away from the keyboard plug? If not get a usb keyboard and make sure you info is backed up...just in case. Good Luck, Tim
Feb 10, 2007 | MSI KM3M-V Motherboard
ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard Logo
188 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
