Question about Car Audio & Video
Dim Display My CD player works fine...sound and all, and sounds good. however, its display is very dim, although there. what can i do to fix that, and there is no button to change the dimmer. My car power had two more wires...for dimmer...but the player had no space for them in it. What can i do?
  • 3 more comments
  • SMMarcus Dec 19, 2007
    Blaupunkt Newport SQR29 - same problem, unrelated to panel brightness control; readable only in complete darkness
  • Rick8086 Feb 22, 2008
    POS. Have the same problem.
  • 1kag Jun 24, 2008
    Sony cdx-1300 dim display barely readable in daylight not readable at all during darkness. all other functions ok. installed in 98 plymouth breeze.
  • Rick Pitts Sep 22, 2008
    Display can only be read in the dark. Everything else works fine
  • Anonymous Nov 06, 2008
    Blaupunkt Newport SQR29 - ditto; barely readable.
    Looking into replacing two bulbs on face...
    New Friend:
Did you ever find a solution? I'm having the exact same problem.
Posted on Nov 26, 2009
On newer stereos, you might have to experiment with the "panel" wire.
I just installed a VR3, and discovered that the more voltage on the "panel" wire, the dimmer the display.
With no connection, you get full (daytime) brightness. With full voltage, you blank the display.
I wired mine up to the car's instrument lights through a 10Kohm trim resistor so I could adjust the "night" intensity. But if I dim the car's instrument lights, the stereo gets brighter. Oops.
Older car -- I can't just flip a software bit. ;)
But I gather a lot of new stereos are like this. The display on my (factory) stereo in the Mitsu dims a fixed amount when the lights come on, but doesn't adjust with the car's instrument dimmer.
Posted on Jul 07, 2008
SOURCE:
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Mar 02, 2017 | Televison & Video
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
[email protected]
Nov 30, 2015 | Bose Wave Radio
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
How do i replace burned out lightbulb in my in my cambridge soundworks cd - 740 clock radio ?
I believe the problem is either a faulty light sensor the unit has to dim the display when the lights dim since it was designed for bedroom use with alrms and snooze button. or it is simply a failure in the circuit that drives the LCDs. Mine has been dim for a long time but I can still see just enough to adjust the sound settings. I tune and set stations by sound. so the display has not been an issue since we do not use it for a clock or alarm. I doubt there is a fix for the dim display.
Mar 10, 2014 | Cambridge Soundworks CD-740 Clock Radio
Display very dim
Thats just judgemental, depeding on sentimnets you have for it...ask yourself a question: why would you buy a new MW if the one you have does the same as the new one you would probably buy?
Nov 28, 2013 | Frigidaire FMV145K Microwave Oven
Marantz CD4000 dim display fix?
CD 4000 have two types of displays. Flourocent type and LCD type. It yours' have flourocent type, the display module is faulty. If it is LCD type, backlight LED is faulty. This LEDs can be replaced.
Jun 05, 2012 | Marantz CD-4000 CD Player
Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
Feb 26, 2010 | Cambridge Soundworks 88CD CD Player
The cds won't play. Once you press play, the cd
Sounds like you have a powre supply issue. It could also be a display issue but if the display is working OK before you hit play I wouldn't think so. When you hit play does the display dim? If it does then the power supply is the problem. If not then the control board has a problem. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Onkyo DX-C340 CD Player
Dim radio/cd player display
The Bulbs have blown you can get special bulbs from the renault dealer have to pull off to of dash to fit
Dec 04, 2009 | Aiwa CDC-MP32 CD Player
Car Audio & Video Logo
958 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
