Question about Zenith IQB50M90W 50" Rear Projection Television
Hi please help me
Every time i turn my tv on i have to hit it in the side to see the picture and then after 20 min it start jumping
  • 790 Answers
Ok! you have lost contact or crack board find the lost contact then re soldered it! do not hit em anymore because can cause damage other big parts! like flyback! H out! and more!
Posted on Sep 23, 2007
SOURCE:
I let my tv play all night long i turn it off then 5 minutes later hit the power button the blue indicator light comes on but no picture or sound i play with the power button and sometimes it just turns...
you must check the power supply unit of the tv which may have bulged capacitor at the secondary output which may need to replace due to it was leak.
Nov 01, 2013 | Sceptre "42"" Lcd 1080P Tv"
I have a Whirlpool Dryer model GEW9200LW1. I have to push the start button 10-15 times to get it to start, then it may run 1 second to 20 min and just shut off with time in the display. then if i push...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Whirlpool Dryers
The Television will not stay on
LOOKS LIKE YOUR CONVEGENCE IC ARE SHORT UNWELD BOTH IC AND TURN TV ON IF IT STAYS ON 450 DOLLASR TO REPAIR
Jun 03, 2010 | Hitachi 43F300 43" Rear Projection...
When I turn my tv the picture jumps it use to stop after 15 mins or so but now it doesnt. The picture jumps up and down and hitting it does nothing.
The sync control is failing, you need a service call for this. But check out the back and see if there is a sync lock knob or a hole with a slot inside it to adjust the sync control.
Aug 11, 2009 | Televison & Video
Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
Mar 28, 2009 | Zenith B25A02Z TV
Jumping picture on Toshiba flat screen model 36HF732
see ur proplem is u hit up or down or previous to much and it thinks ur still pressing it if u have a bos just turn it around and hit reset beleive me its happened before
Mar 26, 2009 | Televison & Video
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
Zenith IQB50M90W 50" Rear Projection Television Logo
35 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
