Question about Dryers
Replaced heater element, now only low heat , programing ok
  • Anonymous Apr 30, 2009
    conections ok , tested with multimeter..thermal switch ok, conducts. 240vac @ relay rely operates,motor starts, neather lo or high heat coils glow. fan runs.
    President:
  • 1,489 Answers
If you're only getting low heat this implies one of the following:
- loose/corroded/damaged connector, or
- bad thermal limit switch/tstat
If you want to pursue further, let me know.
Posted on Apr 22, 2009
  • Samuel Charles Spriggs Apr 29, 2009
    So, what was the problem -- where did I miss it?
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
What is cold resistance of heater element? Bosch SGS56E02GB
If the heater element had infinite resistance, it would be defective. Possibly a defective thermostat.
Jul 01, 2015 | Bosch Dishwashers
Why do I suddenly have no hot water in my electric Premier Plus water heater?
1st check the circuit breaker that supplies power to the water heater. If that is OK then check and see if you have power to the heating elements on the water heater. If not then check and see if the thermostat on the water heater has power to its connections and verify that it is calling for the water to be heated. Last if all these checks are OK then you must have a burnt out heating element. Some can be replaced but you will have to drain the water from the heater before replacing the elements.
Feb 22, 2015 | Water Water Heaters
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
Goes through its program but does not heat water. Bench checked heater element works ok
If the heater element is working, that leaves the thermostat and the control board. You can test the thermostat and rule that out or pin point it as the problem.
Jun 21, 2011 | Beko 24 in. D3731F Free-standing...
Mine runs OK on low for a few hours but then starts flaring and the whole heating element turns bright red with heat. I'm afraid it will melt or ignite the propane bottle.
Does this only occur when the LP tank is near empty? If so that's why it's doing that. If that's not the case, the elements need to be replaced.
Feb 03, 2011 | Mr. Heater MH24T Heater
We just installed a Rheem 50 gallon water heater. When you use any hot water a low pitched vibrations occurs that you can hear in the bathroom and bedroom. When the water heater completes the heating cycle...
Every electric water heater I have ever installed makes a low hum while heating. I believe this is a combination of the current going through the elements and the minerals in the water cooking on the elements. That is the best explanation I have. Hope this helps.
May 11, 2010 | Rheem 81VP6S/430126 Water Heater
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Dec 17, 2008 | Dryers
AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Aug 19, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
Dryers Logo
115 people viewed this question
Top Dryers Experts
