Question about Toshiba Satellite M45-S265 Notebook
Bios m45 password
I have forgot my bios/startup password and need to know how to bypass it
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Re: bios m45 password
It cost me $85.00 today but I have the solution for $45.00. If your interested let me know. VERY EASY to reset
Posted on Jan 29, 2008
  • 1,006 Answers
Yess there is another way:
take a look here
Posted on Nov 16, 2007
  • 457 Answers
You cannot bypass it the only way is to remove the battery inside the laptop for an hour or so, if you do this, it resets the bios. There is no other way unless of course you remember the password.
Posted on Sep 23, 2007
0 characters
3 Points
How to access startup forgot password?
If you mean your BIOS password you will need to remove the battery and then remove the case from your laptop to access the main board, there will be a battery on there that holds the setting when powered off, remove this leave out for 2 mins replace and then put back together and power up, your BIOS should now have no password so you can access the settings again.
Cliff Cook
Jul 30, 2014 | Lenovo ThinkPad PC Laptops
If you forgot windows password,you can use such windows password recovery tool...
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
Siemens SKY_FOX
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Mar 16, 2010 | PC Laptops
How to bypass bios password on hp 4335s
If you know for sure it is a "BIOS" password. You will have to use a "Jumper option" Not hard to do.
Oct 18, 2012 | HP PC Laptops
Forgot password fot toshiba satellite m45-s169
Thats a Power On Password...I believe the only way that you can get around/reset/disable by taking out the battery out of the Cmos. I will be looking for more ways other then that but thats one that i know works...
If you would like to attempt it...i dont recommend it for the no computer people...look up fourms and see if others have had the same problem or if people have taken the computer apart and replaced the cmos battery
Dec 12, 2009 | Toshiba Satellite M45-S165 Notebook
Forgot password cannot bypass BISO to login
You need to remove the CMOS battery from the motherboard to reset it.
Oct 31, 2009 | Toshiba Satellite M45-S169 Notebook
My computer has a password in the BIOS Setting. i forgot it
Do you know what the password is? If so, enter the bios and change it. When asked for a new password, just hit enter. If it asks a second time to confirm the password, just hit enter again.
Good luck
Mar 17, 2009 | Dell Inspiron 8600 Notebook
Toshiba Satellite M45-S351 BIOS password needs help!
BIOS passwords on Toshiba notebooks have to be reset by an authorized service technician who has the CD available to run the utility.  Their notebooks don't contain a battery reset to erase the password.  It was done as a safety feature to prevent theft from happening and it is a very good one.
If you take it into Best Buy or a computer dealer to get it done, you might have to prove that you are the new owner of the computer before it can happen.
Sep 23, 2008 | Toshiba Satellite M45-S351 Notebook
Forgot Bios password
you have to open it and find the BIOS battery, remove it for a few minutes. this does not always work but it's the first step
thanks for rating
Jan 11, 2008 | Toshiba Satellite M45-S265 Notebook
Forgot Password
Which Windows operating system you are using. If its XP you stuffed you will need to reinstall Windows. But try this sometimes the Administrator has no password and you may be lucky. Startup the machine holding the f8 key to safe mode if the the Administrator is available remove the password from you login in the Users Mode. If it is locked than the alternate is to reinstall there is no other solution.
Sep 01, 2007 | Toshiba Satellite M45-S331 Notebook
Bios/startup password
yes, it will still be charged, to reset the bios password you need to locate the cmos battery on the motherboard and remove it for 10 mins or so, but where exactly the battery is situated, i'm not sure.
Apr 17, 2007 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S265 Notebook Logo
251 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
