Question about Rosen CV7080D Portable DVD Player
Landrover LR3 Rosen dvd player wont play burned DVDs
Is there a patch or software update maybe even a special DVD-R disc i can used to recored my sons TV shows and play them on the rosen DVD player in the land Rover?
Thank in Advance!
2 Suggested Answers
  • 246 Answers
SOURCE: rosen dvd player will not turn on - just purchased 2005 land rove
check the owners manual for fuse locations and find the fuse for your dvd system. make sure it isnt blown. if it is, replace it and see if it blows again. if it does, or if the fuse isnt blown, take it back to the dealer and get it checked out on their dime
Posted on Feb 16, 2010
Acer aspire wont recognise cd roms but plays dvds
Have you checked your CD roms? Maybe they are already defective. Try running them in a CD player to see if they run smoothly.
Sometimes, the onboard driver update mechanism isn't that consistent with its result. I suggest that you use RadarSync to scan your computer to see if your drivers are updated.
RadarSync is a specialized PC Driver Update Software. You can scan your computer using the free version but if you want it to update the drivers then you can buy a year or two years subscription of the software to keep your drivers updated.
Let me know if you have any questions.
David
Feb 27, 2013 | Acer Aspire Z3731-UR21P
I got a nb501sl9.. doesnt play burned dvds.. says "please eject playback may not be a option.." tried burning firmware to update... still does not read the disc burned on dvd+r. Says the same...
Maybe this model does not support DVD+R, or the discs you have been using may not have been finalised in other equipment prior to playback in this unit.
Try using finalised DVD-R discs instead. They should work in this player, if not, then it probably does not support burned DVD media.
Nothing you can do, except purchase an el-cheapo DVD player (alongside this one) which can read DVD-R/DVD+R and other burned media.
May 01, 2011 | Sylvania NB501SL9 Blu-Ray Player
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
I'm attempting to burn a video i created on windows movie maker to a DVD+R 4.7 GB/Go, 1-16x disc. I've attempted burning it straight from the option in windows movie maker, and now I just attempted to use...
If the DVD is unreadable by several devices then the DVD disk was burned wrong and is nothing more than you can do.
Assure that you have a region set on your DVD players and a certified DVD playback software on PC. Windows Media Player 10 should be enough if the disk is still unreadable will remain unreadable and ony speciall software with raw access will read it but this is not a solution for you.
I use Nero 7 for burning CDs and DVDs and never had a problem. Maybe when you burned the DVD you set a wrong regional code or you choosed a wrong DVD format that is unknown to your DVD players.
Nov 02, 2010 | Computers & Internet
My clarion VRX486VD will play dvds but not video clips
use nero vision this will work it does the same with mine
pls rate people arnt rating hope this helps
May 11, 2009 | Clarion VRX485VD Car DVD Player
Mini dvds
Yes of course.!
Cheers!
Feb 28, 2008 | HP Pavilion dv6000z Notebook
Dvd
do you mean wont play on dvd players (connected to tv)
if so its because the software you are using is not compatable.or the way you are burning them.for instance if you use nero dvd (mp4)you can only view with nero but you can config to use with any player.If you mean it wont play on other computers its usually wrong format.you can maybe cure this by updating dvd drive firmware.
Dec 09, 2007 | Computers & Internet
Wont burn cds , files , etc
well it could be many reasons why it wont write your burner but first what software you are using for burning. it happens to me before using media player when i try to burn music. the reason was i haven't configure my media player to use my dvd burner for burning because i have dvd burner and a cd burner installed. Now maybe you try to reinstall it using your dvd driver the one which with your dvd burner when you first bought it.
Nov 20, 2007 | Computers & Internet
Rosen CV7080D Portable DVD Player Logo
570 people viewed this question
Top Rosen Televison & Video Experts
Jim London
Jim London
Are you a Rosen Televison and Video Expert? Answer questions, earn points and help others
