Question about Intel Motherboard
After i pulled out the power cord of my cpu its not booting up anymore. Please help me to solve this problem.
  • ikkenom May 11, 2010
    Turn the computer off.Remove the side-panel from the computer-case.Turn the computer on and look inside your computer.Do any lamps light-up? Do any fans start spinning?Do you get just one "beep", or more than one "beep"?
  • Joe Fine May 11, 2010
    What model computer do you have? Does the power come on? Do you get any indication on the screen?
My computer turns on but my screen wont HELP NOW
please check on cables connecting the monitor to your tower/cpu. make sure both ends are plugged in tight. check on the monitor power light aswell, if its blinking or not, if the monitor has been more than 5years old too, its possible thats already dead computers have a life time too especially the old models.
Apr 06, 2011 | Computers & Internet
Please clear cmos if system no display after overclocking
Click the following picture to enlarge:
CPU Overheated
If the system shutdown automatically after power on system for seconds, that means the CPU protection function has been activated. When the CPU is over heated, the motherboard will shutdown automatically to avoid a damage of the CPU, and the system may not power on again.
In this case, please double check:
1. The CPU cooler surface is placed evenly with the CPU surface.
2. CPU fan is rotated normally.
3. CPU fan speed is fulfilling with the CPU speed.
After confirmed, please follow steps below to relief the CPU protection function.
1. Remove the power cord from power supply for seconds.
2. Wait for seconds.
3. Plug in the power cord and boot up the system.
Or you can:
1. Clear the CMOS data.
3. Power on the system again.
If after clearing the CMOS you still have no display, you may have damaged your motherboard, CPU, or RAM. If you need further assistance with this Motherboard, let me know.
Mar 25, 2011 | Biostar G31-M7 TE Motherboard
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Computer does not fire up anymore after CPU exchange.
First, check the PSU on another puter if available. If it works, the MB is the most likely culprit.
Check the capcitors (round tower looking things around the MB). If any are bulging or show brown "dirt", the MB needs replacing unless you know how to replace capacitors (Youtube has tutorials if your brave enough).
You may also have a damaged southbridge. Ebay may have replacement chips (replacing is similar to the capacitors).
Jun 03, 2010 | Asrock P4VT8+ P4 PT800 Prescott Ready...
My computer sometime do not boot, I've got a black screen (No Signal) and hangs there until I unplug the computer from power line. My configuration is: MSI P35 Platinum Combo Bios V1.2(updated), Q6600,...
there are a lot of causes of black screen.. check the ram, or cpu.. or the vga connector.. about the booting.. be sure that your operating system is good.. if not of course not booting anymore
Sep 12, 2009 | Computers & Internet
Acer aspire 4520 won't boot
Try this.
Unplug both AC ADAPTER and remove battery.
Press and hold POWER BUTTON for 30 seconds.
Plug in AC ADAPTER.
Turn on.
After log in, place battery in.
Apr 26, 2009 | Acer Aspire 4520-5950 Laptop
Still odd warning sound when starting the computer
Reset your CMOS...
If you don't have a Jumper to reset the CMOS, pull out your power cord, open the computer, and pull out the motherboard's battery leaving it out for about a day (Don't plug in the computer's power cord during this time period). About 24 hours later plug the computer's power cord back in and try a boot (Don't put the battery back in to your motherboard at this time).
If this problem persists check manuals to see if there is a method to reset the CMOS by moving a jumper. If there is not such a method available you might have to send the motherboard back to the manufacturer requesting the BIOS ROM chip be replaced. Depending on if you're still under warranty or not you might have to pay a small fee.
If at any time the boot is successful, enter the BIOS and save the default settings. Afterward shut down, pull out the power cord, and place your battery back in to the motherboard.
Hopefully you get it fixed.
Feb 02, 2009 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
I am having difficulty booting up the computer. The computer will only power up if I switch the power bar on and off several times.
maybe the power cord from avr to cpu is not set tightly please set it up. second maybe your avr has no power output try to plug power cord direct to the power outlet.
Aug 03, 2008 | Compaq Computers & Internet
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Intel Motherboard Logo
55 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
