Question about Bose Lifestyle SA-1 Amplifier
BOSE LIFESTYLE SA-1+ BOSE LIFESTYLE SA-2
Could you please tell me the difference between both units, as i am wanting to purchase one or the other, thanks Dave.
SOURCE: remote control program codes
want to know the code for bose lifestyle5.
Posted on Jul 23, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
SOURCE: I have a Bose Lifestyle 28 and want to hook my ipod up to it.
if there is a rca input available you can go to a local electronics store such as radio shack and pick up a rca MALE to 1/8 MALE cable
Posted on Feb 03, 2009
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Can I use my bose SA-1 Amp with other brand stereo systems
No!
This is what it says in the manual:
The Lifestyle
stereo amplifier is designed for use with Bose non-powered environmental speakers or
Bose non-powered accessory speakers ONLY
Jan 22, 2013 | Bose Lifestyle SA-1 Amplifier
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Bose SA-3 amp and a non bose sub.. I keep blowing the amp..
How many ohms is your sub? The SA 3 Amp can only handle speaker(s) 6 ohms and greater. A lot of subs, as I understand, are 2 and 4 ohms typically. If yours is 2 or 4 ohms, then that explains it. The speaker would be "straining" your amplifier and blowing it.
Oct 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
SA-2 and SA-3 doesnt work together
its alwaays better just to call bose their great when it comes to this
May 20, 2009 | Bose Lifestyle 18 System
Lifestyle 12, NO AUDIO and a DEAD DISPLAY
You are correct. The display unit is separate from the audio issue. I have tired to work on a few of these units over the years.
Bose is so proprietary in thier electronics and repair that the average electronics technician cannot service them.
Your only luck it to send the units in for service. If you are dead set on wanting the bose units then, $250 may be worth the repair charges to you.
If I was you, I would retire the Bose equipment and go to my local electronics store to purchase a different brand unit.
Jan 29, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Adding SA-3 amp
your media centre and sa-3 are from two different countries they work on radio wavs, if the amp and media centre are different they will never work sell the amp and buy one that is the same region code as your media centre
May 11, 2008 | Bose Lifestyle 38 System
Bose Lifestyle SA-1 Amplifier Logo
464 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
