Question about Sony XM-1002HX Car Audio Amplifier
Sony xm-1002hx my sony xm-1002hx was working fine untill last week it just stoped working... what it is doing is every time i put a new fuse on the amp the moment that my amp trys to turn on it just blows the fuse.... i went to even bigger fuses but nothing...opened amp up to see if i see something inside that is blowen.. looks like new inside... what is going on with my amp..... it is not the wireing tried different amp works fine....
  • Anonymous Dec 01, 2007
    Fuses pop when turn on lead is energized.
  • Anonymous Mar 04, 2009
    i have the same problem. i tried a new fuse and it blew. i took the amp out and opened it. looks great inside. i atached a volt tester to the ground and to the remote lead and showed a current. what could be causing it. nothing looks out of place....
  • 631 Answers
If the fuse blows only after the remote voltage is applied, the output transistors have likely failed. Never use a fuse larger than the one recommended by the manufacturer. It can lead to more extensive damage (including damage to the circuit board) which will make the amp much more expensive to repair.
Posted on Sep 23, 2007
SOURCE:
Sony xplod amplifier xm-1002hx
It saw a spike on Circuit Board.
Mar 08, 2014 | Car Audio & Video
Problem with amp
Check your ground it may not be good enough also check to make sure your remote wire is reading 12 volts with the key on. If it doesn't then you run a jumper off your ignitionin the fuse panel.
Sep 22, 2009 | Sony XM-1002HX Car Audio Amplifier
Problems with my sony xm-2100 gtx amp
check your wires and your ground wire it might be touching something causing it to spark and your amp to go on protect mode also check your fuses..also sometimes this works put your db and all your settings on your amp low as it can go sometimes its just to much power n hits like an impact.
Jun 09, 2009 | Sony XM-2100GTX Car Audio Amplifier
What is the watts of this amplifier
The XM-1002HX is a two-channel amplifier with power ratings of 100 watts x 2 or 280 watts x 1 into 4 ohms and 140 watts x 2 into 2 ohms. ...
Mar 21, 2009 | Sony XM-1002HX Car Audio Amplifier
Sony amp pops, when you turn on the car. how do i fix it
Run an Extra Ground or ReRoute Your Main Ground Straight to the Battery and it should Stop this Popping. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 28, 2009 | Sony XM-1002HX Car Audio Amplifier
Overcurrent protector
The woofer or the wiring may be shorted. Remove the speaker wires from the terminals of the amp and power up the amp. If it powers up, check the wiring and the speaker. If it still goes into protect, the amp may be defective. A short in the wiring or speaker can damage a brand new amp.
Dec 17, 2007 | Sony XM-1600GSD Car Audio Amplifier
Amp and subs just stoped working
Sometimes power problems are not visible. Did you check the voltage at the amplifier with a multimeter?
Dec 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
I have a problem with my amp
Are they all green? If so, that's normal. They go red (or maybe amber?) when the protection circuit detects a problem.
Oct 24, 2007 | Car Audio & Video
Car Audio & Video Logo
313 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
