Question about Frigidaire Freezers
Once in awhile, Circuit Breaker Trips
Frigidaire Freezer Model MFC05M3BW4, with a Manufacture Date of 6-99, is located in the garage.
It's plugged into a GFCI. The breaker box is also in the garage.
The freezer tripped a 15Amp breaker the other day.
The last time was years ago. What may be the cause?
Thank you.
  • Anonymous Mar 18, 2014
    freezer worked fine then sat unlugged for about 3 months. now upon plugging it in, I will run for awhile then trip the breaker.
  • Frigidaire Master
  • 3,361 Answers
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Posted on Apr 22, 2009
Wb73805358
Hello friend, thank you for allowing me to assist you!
I see you are looking for the date of manufacture for your Frigidaire freezer. According to your serial number I show your freezer was produced in 2007. I hope this information is helpful. -Matt
Aug 16, 2014 | Frigidaire Freezers
Freezer trips breaker
Try turning the temp control to off. Plug the freezer in for an hour and then turn the temp control down to start the cooling.
Dec 30, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Can't get freezer to reset model number LFFH17HWC serial numberWB93766371
Hello richardso903 - Once again try resetting the freezer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. Set the unit to ON, by pressing and holding the Power button for approximately ten seconds. If issue persists and freezer does not turn on, then the unit may be experiencing a wiring failure, faulty plug or control board. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Tripping electricity
HI, The reason for the over-pull is due to the unstable conditions located at the main PCB that controls this affected unit. The voltage is not stable, due to the damage located at the PCB(circuit instabilities). Just to be safe, have your local electrician inspect the breaker box for shorts and damage to the appropriate circuit block. If the electrician confirms that the breaker is in good condition; replace the main control board(PCB) that is mounted near the compressor or behind the rear access panel.
Jul 21, 2010 | Whirlpool Freezers
Frigidaire chest freezer- the compressor tries to start for three seconds or so and then the circuit breaker for the outlet trips.
This sounds like a bad overload relay or locked up compressor. If you are very technical, you can do some troubleshooting by checking to see if the compressor pulls "locked rotor" amps when it tries to start. This information should be on the unit nameplate and will be listed under "LRA". This requires special testing equipment (an amprobe). Also check for any bad connections at the plug and the terminals where the cord terminates inside the electrical compartment on the freezer.
Something else to try is to plug the freezer into a different electrical outlet and see if the same problem occurs.
If the freezer is over 15 years old and the compressor is bad, it will not be worth the cost of repairs.
Dec 30, 2009 | Frigidaire 13 cu. ft. / 368 liter Chest...
No power while plugged
It probably has a circuit breaker located on the bottom of the fridge, behind the front filter. Also try looking inside the refridgerator side at the top. It may be red colored to indicate it is safety-related. Just push it in - but don't be surprised if it trips again.
WARNING: RESET ONLY ONCE TO AVOID A FIRE OR ELECTROCUTION SITUATION.
You may have an internal problem, in which case the freezer's circuit breaker is your best friend!
Note that the self-defrosting freezers have a timer that shuts them off periodically so they can defrost. Sometimes the timer does the defrosting in the middle of the day, giving the appearance of a failure. This could be your problem.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Jul 01, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezers Logo
268 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
