Impossible to give you that since there arent any.
This is what Datacard says about SP55:
"Printer Driver 4.0 does not support Windows 98, Windows ME, Windows NT, Windows 2000 and 64-bit Operating Systems or PC architecture"
Here are all avalible drivers and other info about SP55:
A simplex printer can print 2 sided cards you need a duplex upgrade kit. Its is a mechanical "card flipper" that is to be installed in the printer. Contact TulsaBiz.net for more info and upgrade pricing, Also a firmware update.
The printer is not "ready" The printer needs to be ready with a green lite for the install to complete. You can download a quick start guide that will get the printer installed at the link http://tulsabiz.net/?q=node/12
The rollers in the printer that move the card wear out and the rubber degrades over time, You need to have all the roller replaced and the printer should function like new. Contact MIdWestIDSolutions.com for pricing on parts or service.
Hello, The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options. The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer. Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem) Aside from that you: May have a counterfeit (non-Datacard) ribbon A bad RFID tag Someone removed your RFID tag You need a firmware update (weak RFID tag) A bad RFID reviver in the printer, which is a fairly cheap repair. Basically try a new print ribbon if that does not correct the issue, have the printer serviced. www.TulsaBiz.net
Hi!
http://www.datacard.com/id/support_and_d...
Nic
